โFeb-27-2015 10:16 PM
โFeb-28-2015 01:21 PM
westend wrote:
The problem with using a concrete block is that most guys put nothing under it and nothing on top. When the steel is lowered onto the web or sidewall of the block, it is prone to crack. Part of that is why multiple blocks forming a pier are used under mobile homes. The frame load is spread among the multiple blocks.
If you don't have any steel stands, buy 6 X 6's and cut them into cribbing blocks. Either that, or use at least 4 blocks under every support location.
"Cinder block" is a regional thing. No one in the upper Midwest uses that term. "Concrete" is placed and hardened "cement". "Cement" is a mix in a bag, the stuff rolling around in the truck is "concrete mix". Masonry terminology is easy. Try electrical nomenclature if you need a headache.
โFeb-28-2015 12:45 PM
โFeb-28-2015 12:01 PM
โFeb-28-2015 11:38 AM
NMace wrote:
Sorry about the cinder block usage, a euphemism from my youth.
I think I am going to be about 10" at the low end, so it will take only one cement block and some lumber.
You guys are great.
P.S. I do wonder where the "cinder" originated? Seems like we called the athletic track cinder, also. And I think it came out of coal furnaces.
โFeb-28-2015 11:01 AM
โFeb-28-2015 10:51 AM
NMace wrote:
Thanks. It is not in an RV park, but on private land. The goal is to lower the unit for ease of entry for my mobility limited DW. It will be there for at least 6 months and possibly permanently.
So I need to place the jacks closer to the axles?
I have seen houses built on cinder block piers, and thousands of house trailers on them, I had no idea to suspect their structural integrity. I will do a search to see if I can find their load limits. The plan was for 6 piers, about 1,500 pounds per. Anybody know their limits?
Again, thanks for the assistance.
โFeb-28-2015 10:39 AM
westend wrote:
Cinder blocks (MBU's in the trade) are a poor material for supporting weight under a trailer. If they crack and break, your axles will be on the ground. Wood cribbing or metal stands are a better solution.
IMO, supporting the weight of the trailer by using the frame should first be supported close to the axles and then a support towards the end of the frame.
โFeb-28-2015 08:57 AM
โFeb-28-2015 08:42 AM
โFeb-28-2015 07:29 AM
โFeb-28-2015 07:20 AM
โFeb-28-2015 05:15 AM
โFeb-28-2015 04:31 AM
โFeb-28-2015 03:37 AM
