Replacement running lights question
Seminoe_Joe
Clearing out the cobwebs from my 2012 Lance 850 to prep for a trip next month and today I tested the lights. Ran into a problem with the triple light bar above the door, with only the center one working. โ€œNo problemโ€ says me! Iโ€™ll just get a replacement set and swap them out! But, there IS a problem. Problem is, theyโ€™re no longer made. Model is: tmc glo brite 231/7r/2318a
Is there a recommended replacement for this unit?
I see a bunch of 3-LED bars on eBay, but Iโ€™m not sure if thereโ€™s something that would be better. Thoughts?
โ€œItโ€™s all in the reflexes.โ€
2012 Lance 850
2023 Chevy 3500 HD
4 REPLIES 4
Grit_dog
Navigator
Navigator
Presume they're not individually replaceable bulbs?
If not, pretty much any strip will work, IMO.
In lieu of drilling new holes if it doesnt match up, could use some double sided tape for automotive mouldings.
Seminoe_Joe
Yeah. Saw that. Looks like the same product as I scrounged up on eBay.
Iโ€™ll go ahead and order and see how it goes.
Thanks.
2012 Lance 850
2023 Chevy 3500 HD
K_Charles
Try etrailer
srschang
Check this etrailer link. Somebody asked them the same question, and they had suggestions.
https://www.etrailer.com/question-302931.html
Scott
2022 Ram 3500 Dually Crewcab Longbed Cummins, 2019 Northstar 12 STC
