Replacing the propane piping question
NanciL
I just bought a small older model trailer that has copper tubing running from the regulator to a two burner stove and then to a fitting for an outside stove, and I would like to replace it all including the regulator with flexible tubing.
How hard a job is it ?
I have done lots of water piping (both threaded and glued), but never gas.
Jack L
Jack & Nanci
7 REPLIES 7
SoundGuy
beemerphile1 wrote:
Threaded black pipe or copper tubing is the industry standard.
No longer - many newer trailers, my own 2014 Coachmen Freedom Express being one, are plumbed right from the regulator output with propane rated rubber hose. Mine is about 15' long and runs back to about the middle of the trailer where it feeds a splitter which has several outputs to which are connected more rubber hose that then runs up into the trailer to various locations to feed the furnace, fridge, water heater, and stove / oven. There's no hard pipe of any description.
2012 Silverado 1500 Crew Cab
JBarca
Nomad II
Nomad II
Old Biscuit, Thanks for your reply, that brings up a good point.
A question to the NanciL, what exact type of "flexible tubing" did you want to use?
Rubber gas line hose is flexible, soft copper tubing is flexible, and then there is flexible gas line that has an accordion style bellows to it to allow it to flex, or some other type?
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
Old-Biscuit
JBarca wrote:
Old-Biscuit wrote:
Propane hoses or gas pipe
No flexible for regulator or main feed line
Hi Old Biscuit,
Just asking on your statement that seems to have read, " Do not use flexible hose on the main tank regulator." Is that what you meant? If so, are you sure? or did I miss understand something.
If you meant it that way, many many campers are built with high pressure pigtails off the tank valve to the 2 stage cross over regulator and then low pressure hose from the regulator to the main black iron truck line. They use this to allow the tanks to be hooked up easier and the I believe vibration isolation between the main trunk line and the discharge side of the 2 stage regulator.
Please clarify.
Thanks
John
That is correct......high pressure hoses/pigtails and low pressure hose from reg to black pipe
OP asked about 'flexible tubing' which I take to be like the flex tubing used to connect stoves...metal tubing
If OP was asking about 'propane HOSES' then YES
Appropriate high & low pressure propane hoses are standard
JBarca
Nomad II
Nomad II
Hi Old Biscuit,
Please clarify.
Thanks
John
beemerphile1
Threaded black pipe or copper tubing is the industry standard. All copper connections MUST BE flared, do not use compression fittings.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Old-Biscuit
Flexible for stove only
Cooper for other propane appliances
JBarca
Nomad II
Nomad II
Just a heads up on using flexible tubing on LP gas lines.
When using a rubber type hose on LP that is even gas rated, there is a chemical reaction between the LP and the rubber and an oil starts forming in the hose. The longer the hose, the more the oil. I do not know exactly what the chemical reaction is, but it does happen. I have read it, heard about it and even have the issue. I have an 8 ft hose for my BBQ grill that I run off of a 5# LP tank. At the end of that hose it is dripping with oil come the end of the season.
My camper also has a short hose from the tank regulator to the black iron main LP pipe. While I'm sure this hose also creates the oil, since the hose is only about 2 maybe 3 feet long, it has not created the oil like my 8 ft hose does. And the sch 40 1/2" gas pipe is a very big reservoir for what little oil is created to settle in.
Point being, if you do the whole trailer with small rubber hose you may have a large oil problem that will get into your gas appliances.
I also do not know if a rubber flex line is allowed "inside" a camper. It may be, but maybe not as a cracked hose from deterioration could go undetected. The soft flexible copper not degrade like the rubber.
Just some things to think through.
Question, if you have done a lot of water piping using steel pipe, what is the concern of using soft flexible copper tubing? Is it the flares on the end? That can be overcome with a good flare tool, getting good training on the flare process and some practice.
Hope this helps
John
