Rivian E 1/2 ton charging net for more remote campy spots.
Reisender
For the younger outdoors bunch that like to get off the beaten trail a bit. Looks like Rivian is trying to identify with them with plans to set up L2 and L3 charging in popular but most of the way trail heads etc. Interesting read.
https://www.google.ca/amp/s/techcrunch.com/2020/12/08/rivian-is-building-its-own-ev-charging-network...
Jeep is apparently looking at similar ideas but with L2 only...which is probably all you really need.
This would work for those kind of locations. At least for L2. No infrastructure and no licensing. Totally portable. I think some national parks are starting to put these in.
https://youtu.be/a0WujevWAhM
17 REPLIES 17
Grit_dog
Navigator
Navigator
What if they made gas stations that didn't allow Fords? LOL
Reisender
BurbMan wrote:
I didn't see where it said these were solar?
Yah I don't think they did. But just reading some of the scuttlebutt from some of the Rivian enthusiasts are talking about. Some feel that at least the L2 stations may be solar as they would be chimp simple to install. No infrastructure, permits etc. Just permission to locate the charging structure.
I'm not sure how much of a need there would be for level 3 fast charging. Just seems overkill. If its a trail head that suggest a few hours hiking etc. If its full after half an hour and you are hiking for 4 hours you would be tying up the charger for 3.5 hours. Better to keep it at maybe a standard 6 or 8 KW AC level and pick up 30 or 40 KW during the hike etc.
I guess the other questions remain, will they be allowed to put Rivian only accessible charge sites. EG, maybe a code or RFID card so only Rivians can charge there. Not sure that would be allowed on public lands.
I know these are already showing up at some national parks but they are open to everyone.
Reisender
Grit dog wrote:
Reisender wrote:
pianotuna wrote:
Hi,
I wonder what they cost?
Hey Don.
Between 30 and 45 K depending how you outfit them.
But no permitting or construction or infrastructure. Install time of 10 minutes.
Kinda cool.
Guessing he meant the truck not the charging station.
Trucks are $70k +
Reisender, any idea when rivian is going public?
No idea, but haven't been following that close.
And yes, the 30-45 K was the charging setup.
BurbMan
Reisender
patperry2766 wrote:
Geo*Boy wrote:
The Rivian is a very interesting truck. I really enjoyed watching them on the Apple TV series, A Long Way Up, through South America. I would definitely look to them if I were to purchase a electric truck.
Great show. I would consider this truck too but would never give up my diesel for towing
Yep. I think theyโ€™ll be a hit,,,but marketing will be key.
patperry2766
Courage is the feeling you have right before you fully understand the situation
Reisender
rjstractor wrote:
pianotuna wrote:
It certainly is a well thought out device. How many watt-hours can it harvest in a day?
I look forward to purchasing an EV some day and am not an EV hater. But I'm a realist, and I get annoyed at the worthless figures published by EV companies in regards to range and charging. Saying that a charging station provides up to 'X' range is of little value when there are myriad factors that determine that. (the individual car for one)
So, the internet tells me a ballpark output for a solar panel is 20W per square foot in optimum conditions. The panel appears to be slightly wider than a normal parking spot, so call it 12 feet wide and 20 feet long. 240 square feet gives you 4800 watts output maximum. Not quite true level 2 capability but not too shabby if you're only trying to charge 1 car. Showing several cars connected at once is pretty silly, it's like trying to fill a car's gas tank with a turkey baster.
All true. But remember that these have built in storage as well. Apparently customer configurable. 30 KWH is common apparently. So no problem connecting a few vehicles.
rjstractor
2017 VW Golf Alltrack
2000 Ford F250 7.3
time2roll
I hope the charging stations resemble the recent monolith artwork ๐Ÿ™‚
Reisender
If you watch the video I think they mention somewhere around 250 miles. So divide that by four (a kilowatt takes you about 4 miles) then you end up with around 60 ish kw. But really Iโ€™m not sure as that seems about twice as high as I would have thought. Maybe the specs are listed on their site.
Cheers.
pianotuna
Nomad III
Nomad III
Regards, Don
Grit_dog
Navigator
Navigator
Reisender wrote:
pianotuna wrote:
Hi,
Hey Don.
Kinda cool.
Trucks are $70k +
Geo_Boy
Reisender
pianotuna wrote:
Ty for the price.
I think the power output panel is kinda cool Don. For homeowners with a driveway it could be a backup power source. 120 and 240. We are in a Townhouse so not going to work.
