Roadmaster Antisway Bar and AirLift Airbags
Mikell
I have a 2005 Ford F-350 diesel, dually carrying a 2005 Lance 1181. I installed AirLift airbags (LoadLifter 5000 Kit 57394) and would now like to install the Roadmaster antisway bar RM-1139-165 but am concerned about the larger antisway bar bushings interfering with the placement of the airbag bottom bracket. Has anyone with my configuration successfully installed this antisway bar with these airbags?
6 REPLIES 6
Mikell
Thank you Buzzcut1 and AnEv942.
AnEv942
AirLift instruction slightly mention
http://www.airliftcompany.com/content/manuals/MN-671_57394.pdf
2WD 57397& 4Wd 57398 (replacement P/N for OBS 57394) Also mention inverting carriage bolts.
Though I'm sure this is factory sway bar, don't now if it would help with after market, larger, brackets.
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
Buzzcut1
Nomad II
Nomad II
just checked the dually, there may be a cleareance issue with the inside foreward threaded rod from the arilift mount. But that is excess rod that hangs down 3-4" past the nuts on the airbag mount. I see no issue with trimming off that excess length.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Buzzcut1
Nomad II
Nomad II
Mikell wrote:
I did call Roadmaster. They have no information regarding a potential interference. I was hoping someone on this forum has successfully installed both.
I have Airlift 5000s and a Roadmaster antisway bar on my 03 f350 4x4 crew cab long bed SRW, it fit fine. all the attachment points are the same as stock. Lemme go out and look at my 2011 dually it has the airlift extreme 5000s and the stock ford antisway bar just to check to see if there is a difference in the mount spots for the bar.
Mikell
enblethen
I would suggest calling Roadmaster!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
