May-09-2023 08:34 AM
Jun-13-2023 07:56 PM
May-16-2023 06:18 PM
May-16-2023 04:08 PM
May-16-2023 02:26 PM
May-15-2023 07:16 PM
May-11-2023 11:44 AM
Raven33 wrote:
Jerry, I have contacted a few mobile tech's and am waiting to get on the books with one of them. One tech told me that I probably need a new AC and the other said a good cleaning could lower the air temps by 7-10 degrees (obviously going to try that first). It's a 2006 and I'm unsure of the previous maintenance, so there is definitely a chance it could use a good cleaning. I think it's getting enough power as it is plugged directly into the side of a shop (no extension cord). Hopefully a cleaning will do the trick. It's going to be in the upper 80's here next week. I found someone who is going to let me use their portable AC until the rooftop unit is repaired. It's amazing how hot it gets inside these things when the temps go up!
May-11-2023 11:02 AM
May-11-2023 10:20 AM
May-11-2023 05:27 AM
May-10-2023 08:11 AM
May-09-2023 04:28 PM
May-09-2023 04:26 PM
opnspaces wrote:
Portables just flat out suck. If you sit right in front of the portable it might cool you down.
The downside of a portable is it has to exhaust the hot air to the outside that it creates when cooling. This causes a negative pressure inside so the new hot outside air gets pulled into the trailer to relieve the vacuum.
May-09-2023 02:47 PM
May-09-2023 12:51 PM
