As it turns out, my spare disappeared. Seriously. Hopefully, it went to the edge of the road harmlessly when the hoist cable broke. Maybe it was cut off by a thief ... less likely.
In any case, I’m replacing the hoist and of course, had to buy a new wheel. Luckily, I have two tires from when I changed my front to a different style. So, all I’ll need is to have the tire mounted on the new takeoff wheel.
When the takeoff hoist that I found on ebay arrives, the question is “should I attempt to rotate to allow access from the wheel well?” I’ll have to remove the bolts in any case and reinstall.
What would you do?
