โAug-17-2013 05:11 PM
โAug-22-2013 11:01 AM
NMace wrote:
The question I have is why have clearance lights in the first place? They haven't been needed in 70 years, and never if not pulling a trailer.
โAug-22-2013 07:53 AM
โAug-21-2013 06:45 PM
Fishfins wrote:
Thanks a million for taking the time to post the photos. As I understand it, the rubber mat is UNDER the wood frame and on the truck bed? Your camper rests right on the long 2x6s? Your total lift(3"+) comes from TWO 2 x 6 on top of each other + the thickness of the rubber map? 3"+ lift is about what I need for my camper.
Since I already bought the foam, rubber mat, and plywood I'll use what I have for now, but I'll copy and print off your pics and explanation for future reference. Again...thank you very much.
โAug-21-2013 03:22 PM
โAug-21-2013 11:56 AM
Fishfins wrote:
Darn, I sure would have liked to see your cradle set-up. At the rate I'm going I'll have have about $170.00 in materials to get my camper a safe distance above my over-cab lights.
โAug-21-2013 11:37 AM
โAug-21-2013 12:35 AM
โAug-20-2013 08:34 PM
โAug-20-2013 08:14 PM
Fishfins wrote:
Darn, I sure would have liked to see your cradle set-up. At the rate I'm going I'll have have about $170.00 in materials to get my camper a safe distance above my over-cab lights. I don't have the tools to custom-make a cradle like I saw one guy made out of 4x6 treated planks so it looks like my Lance will be resting on a giant sandwich of foam, plywood, and rubber. ๐
โAug-20-2013 03:01 PM
Fishfins wrote:
I see how the plank you used is outside of the plywood. I assume they are screwed together? I bought a 4' x 8' sheet of pink foam insulation. When I put it in my truck bed I had a full inch of space on each side at the wheel wells. Apparently my wheel wells are 50" wide. I don't want to just set the camper down with a full inch on each side to shift on. I don't think I want to tackle the(2) 4"x6" timber job like I saw another poster had made. They look great and probably function perfectly, but I am hoping one of you experienced guys can suggest an alternative way to deal with the 2" gap I have to fill between the foam and the wheel wells. Thanks.
โAug-20-2013 02:14 PM
โAug-20-2013 09:37 AM
โAug-20-2013 09:33 AM
2Gordons wrote:
The cab heights on Ford trucks were changed somewhere between my 1995 Lance and my 2003 truck. We built a cradle to guide the camper into position, and added three 2" x 6" x 8' boards running the length of the truck bed to support the weight of the camper. Under that is the rubber mat that is always in the bed of the truck... it rests on the spray-in bed liner.
We tried the foam insulation, and felt it flexed and moved a bit... especially with the Happijacs we had. As it flexed it would squeak, too. Occasionally, it would slide around a bit. The setup didn't give us a lot of confidence.
We built the cradle and switched over to Fastguns. Much more stable... camper is locked into position by the cradle, well supported by the 2x6's, and held more securely by the Fastguns. Mo' betta.
I just took it all apart tonight, or I'd post pictures. Do a search in TCU for info on cradles and you'll get some good ideas. I think I have 2.5" of clearance between the cab roof and cabover.
โAug-19-2013 09:18 PM
