Shaving new Tire for subaru AWD
winnietrey
Thought I would ask this question in this forum, as from what I read here, you guys seem pretty smart on mechanics.
So here is the story. Wife picked up a large hole in the right rear on our 2015 Suby Forester ( with 15K on the clock). Tire is not reparable. So options are 1)Replace all 4 tires, or 2) Dealer says they will get same tire and shave it down so it matches wear on the other 3. They say all will be peachy.
My understanding is Suby AWD, is extremely sensitive, and if tires don't match as to size (as in tread wear), you will blow the Tranny.
Until yesterday I did not know one could shave a tire. So any thoughts would be greatly appreciated.
Mod If I posted in the wrong place I apologize, please move as you see fit
35 REPLIES 35
Cider
Went through this scenario myself. Our Forester had a non repairable flat on right rear. Subaru comes stock with Yokohama tires, which I really don't care for. Opted to go ahead and replace with a new set of Michelins. Owners manual even speaks to keeping tires at same tread depth or drivetrain issues arise. One of the flukes about Subarus, also cannot run chains for snow.
2017 Tiffin Allegro RED 33 AA
2020 JLUR
Roadmaster Baseplate
Sterling AT Tow Bar
Demco Air Force One Brake System
_DJ_1
I don't mess around with tires, belts or batteries. Every thing gets changed at 5 years. I would head to Les Schwab for a new set of Toyos. If you destroy another tire it won't cost anything with their road hazard guarantee. I've used it twice!! :C
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
RinconVTR
winnietrey wrote:
RinconVTR wrote:
What is Subaru's tolerance for tread depths???!!!???
No one asked this critical question. That's crazy. Know the answer before you opt to do anything but buy one new tire.
Out of Subarus spec?
I do not believe in shaving anything but race tires. So if you're out of spec among tread depths per Subaru, buy 2 new or a new set of 4.
Subaru says 1/4 inch
That is what I've heard as well, but never saw documentation.
If true, the OP needs to know if his old tires are that much smaller than the new ones. I doubt they are. 1/4" is significant ever after 15k miles. But could be close depending on the type of tire and tread wear rating.
And FYI...this is not just a Subaru thing.
Turtle_n_Peeps
No problem at all with shaving a tire. I did lots of them when racing. The only problem I had was getting sick when looking at the thousands of miles of rubber I just shaved off piled up on the floor. :E
You have to measure tires. Just because a tire has the same numbers does not mean it's the same size. We use to "grow" tires to get stagger. We could grow a tire an inch or two so it's very important to measure them.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
time2roll
steve-n-vicki wrote:
What makes you think they are all the same size when new?
Id bet if you measure the tires right now the front ones are smaller than the rears due to them wearing faster
Do you have a Subaru? I find mine does not have the typical fwd wear issues. Very even all around due to the awd spreading the torque.
BenK
This is what the three differentials have to deal with
Why running on good traction and in 4x4 lock WILL destroy the transfer case....why they have AWD...AKA...full time
That the computers expect them all to have the same rev's per mile...calculated for each corner
If a tire isn't rev'ing within an expected rev per mile...it is slipping, skidding,etc...so those computers will "do something"
Then, that the three diffs will slip if not LS or locker...locker on the center diff (third member) is 4x4 lock...AWD is the full time and has a slippage mechanism...in this discussion...fluid coupled third member
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
winnietrey
Subaru says 1/4 inch , between tires. Buying two does nothing other than blow the diff up. Because on a subys as far as I can tell, it is not a 2 tire thing it is a four tire thing, due to the fact subys, are AWD all the time.
steve-n-vicki
RinconVTR
All_I_could_aff
There's more difference in tire radius to the ground with one tire 5 psi lower than the other 3 than if one has full tread and the other three have half tread. I'm not saying it is ideal to have one new, but on a 28 inch tire example, half tread might be half inch shorter than new. That's about 2 percent.
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
BenK
Two issues and naturist is spot on in regards to fluid coupled third members...it will get hot enough to burn...but inside gearbox...little fresh air...so it continues to heat up even more
It will spew hit fluid out the vent and will flame As soon as it gets fresh air
Or, it will lose lube properties...to then have the bearings go metal to metal...and fail by seizing...which might crack the gearbox case...to allow fresh air in...to then flame...
Other, is that ABS,Traction control, AWD, etc computers counting revs per mile for EACH wheel....it might see that one outside of the expected rev's for THAT condition...one might set the brakes, ABS buzz one tire, or what other components and/or systems are in that game...
Shaving tires is NOT as easy as it sounds...
The tread profile MUST be kept and there are cams for the shaver head to follow
The tire HAS to be ROUND with in spec for that tire and the other three
A BIG ETC...worked my way through college as a tire monkey...
If me, I'd get FOUR new tires. Ask how much the dealer will pay...most likely no...so sell them on Craigslist/etc
dangerbird
Besides the above mentioned mechanical issues, there can also be control issues when different wheel speeds are detected by the speed sensor at each wheel. It can affect anti-lock braking, traction control, and vehicle dynamics control.
Carl
Mortimer_Brewst
My experience with OEM tires is that their quality is lacking. I would look at the reviews of the tire on tirerack.com. If the reviews are good I'd go for the shave. Otherwise I'd get 4 new ones.
If ethics are poor at the top, that behavior is copied down through the organization - Robert Noyce
2018 Chevy Silverado 3500 SRW Duramax
2019 Coachmen Chaparral 298RLS
Searching_Ut
Had to buy a new Michelin for the wifes Awd Equinox and have it shaved to match the other three OEM tires at around the 20k mark. They now have approx. 55k on them and look like they have at least another 10 to 15k left. Some OEM tires do much worse. I doubt I'll get 30k out of the OEM tires on my Ram.
2015 Ram 3500 Laramie CTD, 4X4, AISIN, B&W Companion Puck Mount
2016 Heartland Bighorn 3270RS, 1kw solar with Trimetric and dual SC2030, 600 watt and 2k inverters.
