โApr-06-2020 04:33 PM
โApr-10-2020 06:00 AM
โApr-09-2020 09:56 PM
โApr-09-2020 07:41 PM
Dave H M wrote:
Wow all this info about servicing the trans and at such close intervals (like 15000 miles) just blew me away.
I yanked out the ops manual on the 2012 F 250 and it specifies the first change at 90K. If it is good enough for Henry, it is good enough for me. :h
However I concede that if you don't wear out the drain plug or the pan bolts it won't hurt s thing. :W
โApr-09-2020 01:13 PM
โApr-09-2020 11:57 AM
โApr-09-2020 06:42 AM
JIMNLIN wrote:mike wrote:
That was my point. the 2001 had a 4L60E, the new 1/2 tons do not have a 6L90E that is 3/4 ton and up. You have a 6L80E.
My bad....your correct. The 2016 1500 chevy has the 6L80E tranny....and is a ***** to drop the pan even though it has a built in notch on the pans bottom for that purpose. Terrible GM engineering on that part. ...so says one chevy dealer tranny mechanic.
โApr-09-2020 05:10 AM
โApr-08-2020 03:35 PM
2003silverado wrote:
My truck does have the crossover pipe below the transmission pan, but with the shape of the pan it had enough clearance to sneak the pan forward and then down.
โApr-08-2020 03:33 PM
JIMNLIN wrote:ls1mike wrote:blofgren wrote:
I'm glad to hear they improved this. I had to drop the exhaust on my 2001 Yukon and it was still a major PITA to get the pan to clear. :M
Half ton vs 3/4-1 ton. 4L60E vs 6L90E. Nothing is shared between them.
LOL..1500 GM trucks haven't used the old 4L60E tranny in years. The wifes 2016 1500 chevy 5.3 has the 6L90E tranny.
I asked my chevy dealer to change fluid and filter in the L90E in the wifes truck. At 49k miles they recommended a tranny flush now and a filter change at 75k miles due to this trucks usage.
If your 2500 doesn't have the cross over pipe under the pan why wouldn't it be a straight drop like older GM trucks.
โApr-08-2020 04:58 AM
โApr-07-2020 05:39 PM
โApr-06-2020 11:20 PM
โApr-06-2020 07:35 PM
โApr-06-2020 06:05 PM
