Small water heater leak
TexasATM
I found a small water heater leak on my trailer the last time I was out and finally started troubleshooting it. It is a VERY small leak, only a few drops every couple of hours, but enough to be noticeable. It appears leaking out of the upper fitting where the plastic goes into the actual heater body where there is some white sealant. I've attached pictures below to give an idea of what the issue is.
Anyone have any experience fixing this issue? What's the best way to tackle it? I'm heading out on a trip on Friday and would like to have this cleared up by then.
Thanks!!
- Steve
2011 Jayco 32BHDS
7 REPLIES 7
TexasATM
Pulled the fitting out, put some teflon tape on it and put it back in. No leak! I thought about replacing with brass, but didn't think it was necessary since the plastic fitting wasn't bunged up.
Thanks for the help!!
2011 Jayco 32BHDS
enblethen
Yes, the grey check valves or adapters are just threaded in 1/2 inch threaded both ends. Ace Hardware normally carries them. I have not looked at Lowes or Home Depot!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
RoyB
We go to LOWES Hardware for anything and everything we need to maintain our RV's electrical and plumbing.
If we need to order anything it comes from AMAZON...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
TexasATM
Thanks for the tip. I'll pull it out tonight and reseal it. I'll look for some of that teflon tape as well. Wouldn't hurt to have some around.
2011 Jayco 32BHDS
SDcampowneroper
Steve,
It lookslike uo have an Atwwod aluminum tank with brass to PEX adaptors. If the leak is between the tank and the brass, where you see the white thread sealant, then remove it and reseal with tfpe tape or paste. I prefer Harvey # 55 yellow teflon tape, rated for gas and high temps.
Should it be the PEX adaptors, a minor tightening of the nut should do, do not over do it, the back parts of the plastic nuts break easily if over tightened . They have a neoprene cone shaped washer that seals very well when aligned properly.
Max
TexasATM
Do they just thread in? Where would I get brass replacements?
2011 Jayco 32BHDS
enblethen
I would say that the grey check valve(s) are your problem.
I would replace them with brass.
Use Teflon tape and not the paste.
Bud
USAF Retired
Pace Arrow
