โJun-03-2015 12:04 AM
โJun-14-2015 08:32 AM
mobeewan wrote:
I cut 1/4 PVC pipe to 4 inch and 24 inch lengths and glued them together using an elbow and added a coupling to the long end to make an extension handle to reach the valve. I notched the open end of the coupling to fit over the FW tank drain valve. I can reach the valve with it by bending over and looking under the trailer.
โJun-14-2015 05:58 AM
โJun-13-2015 10:05 PM
โJun-06-2015 04:37 PM
โJun-05-2015 10:28 AM
Old-Biscuit wrote:
Why not just extend current line out to an easy to reach place and install a manual valve on end of new line???
No DC power required just some PEX, fitting and pipe strap
โJun-04-2015 06:49 PM
โJun-04-2015 06:06 PM
โJun-04-2015 03:45 AM
โJun-03-2015 12:20 PM
โJun-03-2015 11:31 AM
โJun-03-2015 11:23 AM
โJun-03-2015 07:18 AM
Vulcan Rider wrote:RoyB wrote:
Sitting here wondering about what the CONTROL SWITCH PANEL LABEL would be named especially for the BLACK WATER TANKS..
I think you misunderstand.
This particular valve is NOT appropriate for emptying holding tanks of USED water; only the fresh water tank.
โJun-03-2015 06:15 AM
โJun-03-2015 05:12 AM
ezrydrs wrote:
Has anyone tried one of these for a dump valve on the fresh water tank? My current valve is really hard to reach and these 12v solenoid operated valves can be had for about $25. It is a normally closed valve that would be turned on to empty the tank.
Valve
