Specs for a small camper
Damdifino
I'm looking for a camper ~22 feet long. Prefer double axle, 4 seasons, onboard generator. Any suggestions for me? TIA
2014 Arctic Fox 22H.
2009 Toyota Land Cruiser URJ200 Series
9 REPLIES 9
patperry2766
https://imperial-outdoors.com/x195/
Everything but a generator
Courage is the feeling you have right before you fully understand the situation
Texas_Nomad
Look at the Coachmen Freedom Express (192RBS).  I has your exact size and dual axles.  It has plenty of room to store a small, quiet inverter.  Four seasons???  Not so much.
QCMan
Nomad III
Nomad III
You might find that unicorn but it will surely not be four season. Even an ice fishing rv is not four season as it has no air conditioning.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
valhalla360
Nomad III
Nomad III
Buy a 22ft double axle and have a welding shop install a box on the a-frame for a generator, then add tank heaters.
Problem with getting a turn-key unit is most people looking at small trailers aren't looking for 4season and generators. They want light weight for marginal tow vehicles and they don't want to lose storage in such a small unit.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Why would one go through that expense and all the modifications needed to make it a turn key setup?  Especially when there are so many campers with built in gennys in that size range?
I guess unless the guy just wants to pack a portable genny with. In which case nothing need to be done besides throw a genny and a cord in the back of the truck along with a gas jug.
-move LP tanks (where?)
-add genny
-add fuel tank or can storage
-re wire
-modify framing
That's the point...there aren't any in that size range with a built in Genny and the other requirements.
While it sounds like a lot, it's a pretty simple change to add a rack above the propane tanks for a portable generator (they even have premade bolt on versions...no need to move the propane tanks and hardwiring it into the trailer would purely be optional.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
bid_time
Nomad II
Nomad II
22 feet long with 2 axles and a generator - youโ€™re looking for a unicorn.
Agree that 4 seasons is sort of a unycorn. Iโ€™d really think hard about how much the winter provisions are worth vs how cold and how many nights in the cold.
But 22โ€™ and onboard generator is nowhere near being a unicorn in bp toyhaulers
OP take a look at small toyhaulers. You get more cargo capacity and higher rated axles that everyone complains about with a lot of TTs and common built in gennys with fuel tanks.
Bonus is generally more โ€œspaceโ€ inside due to the open concept. Even more important in a smaller camper.
Just moved on from a 25ft toy hauler....interior accommodations aren't close to similar size travel trailers plus it pretty much rules out slide outs making it drastically smaller.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
