โMar-08-2014 03:12 PM
โMar-10-2014 05:51 AM
Redsky wrote:
Second option is to replace the factory rims and tires with 19.5 rims and 19.5 tires rated at 4400 lbs. per tire which will cost you about $3500. This will increase the payload up to over 5,000 lbs. but is expensive.
โMar-10-2014 12:24 AM
jefe 4x4 wrote:
Teach,
It looks like you have not purchased a TC as of yet. If that is indeed the case, consider the paradigm shift of buying a smaller camper and a bigger truck yet. Some of the most successful TC-er's on here have learned the hard way about reading the GVWR on the door pillar. Consider a TC with a wet weight of around 2000 pounds and putting it on a dual rear wheel, long bed,3500/350 truck of choice with the highest GCVWR.
The rr axle load rating on my Dana 80, 35 spline, FF, 1.53" axle is 13,500 pounds. How can that be with the GVWR on my rig of only 8800 pounds? Simple answer: tire rating. The formula mfgrs use is, "The lowest rated part in the chain IS the GVWR".
My rear tires are 33-15.50R16's on 12" wide rims with a 3750 pound rating and a 16" wide foot print. They are defacto super singles or Duplex tires meant to take the place of a set of duals. My fronts are 33-13.50R16's with a 9.5" wide footprint. Lots of tire/air space to float on. So what? If i deflate them down i can run the beach or sand dunes or down a sandy arroyo. Also, to keep the XTC concept going, I am constantly playing with pressure in tires to fit the road surface. On terrible washboard, I'll deflate down to 30 lbs. front and 28 lbs. rear. Goodbye washboard. The tires become a flexible part of the suspension. Modern tires can take it.
So, I have neither SRW skinnies, or DRW skinnies. It's not for everyone.
Some more to think about on my 2001.5 Dodge 2500 camper special:
1. GAWR: frnt axle: 5200 pounds
2. GAWR, rr axle, non-camper special: 6084 pounds.
4. GAWR, rr axle, camper special: 7500 pounds
5. combined GAWR: non-camper special: 11,284 pounds
6. combined GAWR: camper special: 12,784 pounds
My loaded wet weight rolling down the highway is about 10,200 pounds.
Any 350/3500 will have a higher rating than above.
Always, always, always, did i say always? get a much higher weight rated truck than your camper requires. So, this means a duallie. This is such a hard paradigm coming from a TT or 5th. There is just nothing sexy about a duallie, unless you like big hips. There is something to be said about under stressing by not getting near your GVWR.
Of course coming from either a TT or a 5-er, downsizing your living quarters can be a challenge. IF...you can do with less interior space, take advantage:
1. park in a regular parking place or along the curb.
2. stealth camp in a regular parking place or along the curb.
3. camp in ANY N.P. or N.F. campsite that has length restrictions.
4. No set up.
5. travel like crazy, pull off in any short pull out along hwy 1.
6. drive out from under the TC and have a multipurpose rock truck.
7. drive down a two track road and have less worries about getting stuck or trying to turn around.
The folks posting above know the TC business from many perspectives. Take advantage.
Happy hunting,
regards, as always, jefe
โMar-09-2014 10:08 PM
โMar-09-2014 08:14 PM
Redsky wrote:
Several ways to get around that limitation. One is to replace the stock 3195 tires with 3750 (Nitto or Toyo) rated tires to gain 1100 lbs. more load capacity at the rear axle. I did this and it cost me $500 out of pocket as I sold the factory tires on Craiglist. Second option is to replace the factory rims and tires with 19.5 rims and 19.5 tires rated at 4400 lbs. per tire which will cost you about $3500. This will increase the payload up to over 5,000 lbs. but is expensive.
โMar-09-2014 06:45 PM
โMar-09-2014 05:50 PM
โMar-09-2014 04:29 PM
โMar-09-2014 03:35 PM
โMar-08-2014 08:36 PM
โMar-08-2014 08:02 PM
welsteach wrote:
Considering tc that weighs roughly 3800 dry. Would a 1 ton single rear axle be okay or do I need to look at double axle only. Please, no truck brand wars. Stick to axles. Thanks.
โMar-08-2014 04:18 PM
โMar-08-2014 04:00 PM
โMar-08-2014 03:38 PM
โMar-08-2014 03:36 PM
โMar-08-2014 03:29 PM
