SRW vs Dually
4x4ord
Delete
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
57 REPLIES 57
ACZL
Here's a bit of a twist if you will on this topic. On another forum, a poster states how he is getting a toy-hauler w/a dry GVW of 16K and max GVW of 20K. Has a '03 F350 SRW w/ 7.3 with things being modded. Most of the replies are telling him he should be looking at a dually, but he insists the '03 will do just fine and is even considering making it into a DRW (states the frame is same for SRW/DRW for year). Ford says max 5er wt is 12,700 for that year. Don't know about ya all, I'm heading' in opposite direction.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Me_Again
jshupe wrote:
philh wrote:
6 tires cost more than SAME BRAND 4 tires
jeeze this is a tough crowd ๐Ÿ™‚
Sizes based on 2019 Ram 3500... Picked three random tires, from different brands.
TireRack - General Grabber A/TX - LT285/60R20 - $309.99/ea - $1,239.96/set
TireRack - General Grabber A/TX - LT275/70R18 - $223.99/ea - $895.96/set
TireRack - General Grabber A/TX - LT235/80R17 - $172.99/ea - $1,037.94/set
TireRack - BFG AT2 - LT285/60R20 - $393.99/ea - $1,575.96/set
TireRack - BFG AT2 - LT285/60R20 - $252.99/ea - $1,011.96/set
TireRack - BFG AT2 - LT235/80R17 - $197.99/ea - $1,187.94/set
TireRack - Michelin Agilis Crossclimate - LT285/60R20 - $319.99/ea - $1,279.96/set
TireRack - Michelin Agilis Crossclimate - LT275/70R18 - $254.99/ea - $1,019.96/set
TireRack - Michelin Agilis Crossclimate - LT235/80R17 - $254.99/ea - $1,529.94/set
For two of the three, it's cheaper to replace tires on the DRW.
I added the LT275/70R18 to your list. It re-enforces why I bought a truck with 18" vs 20" Rims.
And:
TireRack - Michelin Defender LTX M/S LT275/70R18 - $254.99 - $1,019.96/set
Chris
n0arp
2000 Country Coach Magna 40',
4380W solar, 22.8kWh LiFePO4@48V, 450AH AGM@12V
2020 Jeep Wrangler Unlimited Rubicon 2.0T, cloaked on 37x13.5s
Cummins12V98
The tires that come on a RAM DRW are different than the 18-20โ€ tires on their SRW trucks.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
philh
Me_Again
Cummins12V98 wrote:
MeAgain what did you pay for your 18's ?
On 6/24/2017 I purchased 4 LT275/70R18E's Michelin Defender LTX MS from Costco for $910.31.
IdaD
Cummins12V98 wrote:
philh wrote:
one costs more to put new tires on
Does it? I paid $1,278 out the door for top quality Michelins. What does a top their modern 18 or 20" set cost?
Sounds about the same depending on where you go and what you buy. I just put on a set of Falken Wildpeaks a couple of weeks ago to give them a shot and they were a little less than that, I think around $1100. Stock size, 275/70R18. I was planning on installing the new DT version of BFG KO2 or Cooper's ST Maxx before I got turned onto the Falken's by a poster here and I think those were both right around $1300 installed.
2015 Cummins Ram 4wd CC/SB
larry_barnhart
We bought a dually because we wanted the best tow vehicle and have never thought it wasn't the best decision for us. Two tires on the rear cannot beat four tires on the rear. Chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
Cummins12V98
IdaD wrote:
This one is easy. DRW if you need the carrying capacity because you need it. If you don't, SRW because they're better in every other way.
Aint gots da SEXY hips!
Grit_dog
Navigator
Navigator
deltabravo wrote:
Me Again wrote:
Just for the record, today's SRW have the capacity of your father's dually,
They don't even go back that far..
My 2009 dually is a wimp compared to the GM SRW trucks of 2011 and later.
Only on paper, if you believe that.
4x4ord
I was on the Ford build and price site and found it interesting that when I selected an f350 platinum the default vehicle was a dually. When I changed my selection to a SRW short box the price increased by $1510.
B&W Companion
deltabravo
blofgren
jerem0621 wrote:
Learjet wrote:
Except! if a tire blows out towing a trailer...SRW not better ๐Ÿ™‚
If itโ€™s a front tire you are still jacked up
tires
Towing a large fiver, the chances of a rear blow out are MUCH higher than a front.
Another pro for the dually is that you can run a much lower pressure in the rear tires even when towing heavy which contributes to a much better ride. And I love how cool the tires stay.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
blofgren
Not true - DRW looks MUCH better! :B
