Sep-24-2017 11:25 AM
Sep-27-2017 07:14 PM
Sep-27-2017 07:09 PM
woodhog wrote:I'm not sure exactly what "poor ground clearance" is. I have a lifted Suzuki Samurai I run through the Rubicon Trail. Some of my wheeling buddies with monster wheelers say it has poor ground clearance. Whatever clearence your truck now has would be reduced by about 3 inches. As I previously posted, it is made of thick steel tubing, not thin wall like jacks. It is seriously bolted on, no screws. As I recall, the jack only have about 18 inches of travel so you would have to work with that. I would not recommend the lift for a serious off road vehicle.
They look like they have poor ground clearance, any problems with
running them high and dry on rough road conditions?
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Sep-27-2017 06:53 PM
notsobigjoe wrote:I am not sure there is a correct way. I did not think of the weight factor, but it does make sense. Depending on which jacks they are using, I think they are about 3000 LBS each. When I install mine on my DRW I will take another look at the weight issue. I think I am okay with the single jack on the driver side.Reddog1 wrote:
notsobigjoe, any particular reason for mounting the single jack on the passenger side? Does the two jack side cause problems with the fuel filler?
Wayne
Mont peters said I should have the two jacks under the heavy side. The fridge is in the slide as well as the batteries are all on that side. Most would have installed it the correct way but he said I and a couple of others were the exception. It was a little tricky in the beginning being on the wrong side and all. Over time it became normal. I have no problems with it anymore.
Toad: 91 Zuke
Sep-27-2017 06:32 PM
SidecarFlip wrote:
It is interesting but would never work for me. I look for places where the road ends....Camping for me on my property in Northern Michigan, getting in is so tight (on a seasonal 2 track 4wd road) that, if I met someone coming the opposite way, one of us would have to back up a long way and it wouldn't be me because I'm usually pulling a trailer with my quads on board.
It's so tight that first trip up in the spring is a chainsaw / tree saw excursion. I have to cut my way in just to clear the sides of the camper.
Why I sold my Lance HS and bought a pop up. Overhead clearance is just as bad (tight) as side clearance. First (and only time) I took the Lance up there, I spent a couple hours in the bed of my cousin's RAM with a pole saw, cutting off limbs just so I could get in. I like to camp in the forest but it comes with a price.
Getting back to the OP' first post, they were looking at the system to use off road on sand and it forested conditions, probably not as dense as what I have but, will it work in that situation? You say you camp on concrete, asphalt or hard packed dirt. I don't think they do or at least they didn't allude to that in their original post....
Sep-27-2017 06:19 PM
Sep-27-2017 03:52 PM
I would like a system on our ordinary jacks that allow them to swing
horizontal when travelling, these are even lower.
Sep-27-2017 03:40 PM
Kayteg1 wrote:
Those pictures trigger my curiosity.
When your dually is 8 feet wide, the jacks have to make about 9 feet?
Sep-27-2017 03:38 PM
Wayne
Sep-27-2017 02:57 PM
Sep-27-2017 02:40 PM
Sep-27-2017 02:25 PM
Toad: 91 Zuke
Sep-27-2017 12:32 PM
Sep-27-2017 11:51 AM
Sep-26-2017 07:45 PM
burningman wrote:I too paid more for my lift (about $2500) than my TC (about $1000 before upgrades). I also said I never would go back to "corner peg-legs", but I have. Went from my SRW 2WD to my new to me DRW 4x4. I had to remove the lift for the DRW. I have every intention to modify my lift from the SRW to DRW this winter.
... I'd never, ever go back to corner peg-legs. I paid more for my Stable Lift than I did for my camper. Because it's that worth it.
Toad: 91 Zuke
Sep-26-2017 03:49 PM
