Storage blocks
handye9
Storage spot for my TC, is unlevel. About four inches, side to side.
Without blocking, the jacks don't extend far enough to get the camper off the truck. The camper has a couple inches clearance on one side, and still sits on truck bed on the other.
I have used 2 X 12's, stacked up, (two high one one side, five high on the other) to compensate for height difference. Over time the 2 by's crack and need to be replaced. Then, I tried Lynx (plastic) leveling blocks. They too, over one winter of storage, have weathered, warped, or cracked.
Is there such a thing as a lite weight (keyword lite) blocking material, that will stand up to the weight and weather?
Something ready made, or, something I could make?
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
6 REPLIES 6
d3500ram
Is it possible to dig lower the side that is too high to level the rig?
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
Camp__Forrest__
The first place that we stored our TC was a dirt lot with a similar problem. I asked the property owner if I could level it with some road mix gravel. He was fine with it. It only took one pickup load to level it. As an added bonus, we no longer had to deal with mud in our spot.
-2000 Chevy K3500 CC DRW 7.4L, Auto; 2000 Arctic Fox 1150 WB; 1999 Bayliner Capri 1800LS Outboard
-Air Lift bags, Torklift tie-downs, Superhitch w/48", Rancho RS9000X, K&N FIPK, MagnaFlow exhaust.
Grit_dog
Navigator
Navigator
Plywood?
AnEv942
This thread list extension for atwood -I believe availble for others.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26667400.cfm
This thread for happijacks
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25554684.cfm
Mark
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
Reddog1
I agree with the jack extensions. I had them on one TC, and never had any issues with them. They are pretty simple to make, and they bolt on. I do not know if you can still buy them or not.
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
camperpaul
Go see Bruce at LBM Trailers and Hitches on GBR, just North of Belvidere.
He has some jack extensions you may be able to use.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
