Surge Protector?
Geewizard
How many of you TCers use a portable surge protector between your AC source (house, RV park pedestal, generator) and your TC?
Think it's necessary? Don't think it is?
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
31 REPLIES 31
Bumpyroad
Wardster wrote:
After one season rolling the dice, we just ordered the new Progressive Industries EMS-PT30X to protect our TC from potential electrical gremlins.
sorta neat, has a weather cover over plug
bumpy
Wardster
2016 Northern Lite 8'11" Q Classic Special Edition
2003 GMC 2500HD Crew Cab 4x4 - Duramax/Allison
lakeside013104
When in a commercial CG I always use a surge protector. I plug the S/P into the pedestal and turn on the breaker. The S/P will indicate a neutral ground and any reverse wired conditions. If the S/P indicates all is well, I turn breaker off and connect to TC umbilical cord and turn the breaker at the pedestal back on.
The S/P hopefully will complete it's job of protecting my camper from any electrical surges. As others have mentioned, good idea to use a good quality surge protector.
Lakeside
Crabbypatty
I am seeking a surge device however I have also heard that some of the hard wired protectors block generator power. I dry camp as much as wet camp, and also have 428 watts pv on the roof, but that shouldnt matter. I would like to have it hard wired as its one less hing to do as opposed to plug in portables. Portables I just wouldnt plug it in with the genny.
Does anyone have any experience with using portable generators and hard wired surge protecters??
John, Lisa & Tara:B:C:)
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
roadtripRN
ended up in the wrong place. apologies ๐Ÿ™‚
deltabravo
Mine has the bypass feature via the remote I have mounted inside.
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
Bumpyroad
which is why I wouldn't have one without a bypass feature.
bumpy
TxGearhead
^^^^Someone who really knows will post, but I think you just need a "smarty plug". The Progressive is not seeing a ground when the generator is running.
I think, maybe, sorta.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
deltabravo
I have a built in version of the Progressive unit. When I use my generators to power my A/C, I absolutely hate the thing, because it cuts power when the A/C tries to start, then the A/C won't start due to locked rotor stall, then the surge protector cuts power again.
The only way to get my generators to reliably run the A/C is to turn on my inverter and let the inverter start the A/C so it is up and running when the surge protector passes power. At that point, there's no "low voltage" as the A/C tries to start because it is already running.
Someday I will remove it and got for a portable unit.
Bumpyroad
2oldman wrote:
pianotuna wrote:
Why?Because the cheapo doesn't protect you from much.
It protects your wallet. ๐Ÿ™‚
until that time that it doesn't. :s
bumpy
edatlanta
jimh425 wrote:
I don't usually have hookups. If I was going to be going to a lot of different parks, I'd probably use one all of the time. They aren't that expensive. I guess it comes down to how lucky you feel.
I never ever plug in anywhere without my EMS-PT50C and have had problems at my home base site which is a lot in a residential area, not a campground. Two months ago I was getting shut down by my PT50C due to high voltage on one leg. The power company didn't even know it was happening, but after calling them daily they got on it, found the problem, and stopped it. They even thanked me for staying on them since they initially didn't believe they had a problem.
My point is you can have power problems anywhere. In the above case the entire town was getting this spike and didn't even know it.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
jimh406
big jim 2 wrote:
When I told my daughter (an insurance agent) about it she said how much is your insurance deductible I said $500. So if all my electrical appliances were fried I would have all new for the price of the my deductible. I decided to pass on the purchase!
However, what would the inconvenience be worth? That's the tough one.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
Lwiddis
You want to roll them dice, please do.
big_jim_2
For 13 years my wife and I have traveled from north of Fairbanks to Key West. From Nova Scotia to California and most if not (all states in between)> We have plugged into hundreds of outlets and have never experienced one problem. After reading all the (saved) stories I have read on these forums I decided to by a progressives 50 amp surge protector at about $500 dollars. When I told my daughter (an insurance agent) about it she said how much is your insurance deductible I said $500. So if all my electrical appliances were fried I would have all new for the price of the my deductible. I decided to pass on the purchase!
