โApr-02-2015 12:14 PM
โApr-07-2015 11:24 AM
โApr-07-2015 10:13 AM
โApr-07-2015 07:52 AM
โApr-06-2015 04:24 AM
โApr-05-2015 07:04 PM
โApr-04-2015 05:54 PM
โApr-04-2015 10:29 AM
Major Dad wrote:augustpilot wrote:
I have 2014 Dodge Ram 1500, 5.7 Eng. 30 ft Autumn Rideg trailer . Tongue weight 900 lb. equalizer hitch. All hooked up the rear of truck is down about 4 inches. Folks have suggested Firestone airbags, stronger springs, etc. looking for help from folks who have experienced this and the ways you cured problem and got your dodge 1500 approx level. Thanks
Here's the manual with step by step instructions. I would first check the inside of the driver's side door to see if your Ram model has enough payload for that trailer's loaded tongue weight. The unloaded tongue weight of my 33.5' trailer is nearly 1000lbs unloaded, and my 2010 Ram 2500 Megacab tows my loaded trailer almost exactly level. Without the spring bars, the rear end squats significantly. The manual shows you how to measure and adjust your weight distribution bars if the rear end is squatting and front end rides high.Equalizer manual.
โApr-04-2015 10:22 AM
โApr-04-2015 08:15 AM
โApr-04-2015 06:12 AM
โApr-04-2015 05:51 AM
โApr-03-2015 04:45 PM
โApr-03-2015 03:11 PM
cyntdon2010 wrote:
Beemerphile, said
don't worry about rear sag. It's supposed to sag when loaded.
Don't listen to him..
If your front end is Up.. and back is Down. be safe and purchase the airbags there is a how to video on youtube.
โApr-02-2015 03:56 PM
