Swap from St tires to LT
ChuckNTruck
I dont want to start another LT vs ST debate. I just wanted to show how i did the swap on my trailer.
I used lift block designed and machined for trailer axles with larger u-bolts to lift the axles 2 inches. Then i swapped the 14in wheels with 205/75R14 tires to 15in wheels with LT235/75R15 tires. These are the smallest LT tires i could find. I have put about 1000-1500 miles on it so far and i have not noticed any difference in how it pulls or rides. But i like the extra 800lb capacity thee tires provide and the higher speed rating. I also added a BAL tire carrier so i wouldn't damage the rear bumper.
My X-chocks still fit between the tires perfectly and i have zero clearance issues anywhere.
2015 Ram 2500 CTD 4X4
2017 Heartland Sundance XLT 281DB
26 REPLIES 26
hohenwald48
ChuckNTruck wrote:
I used 2in blocks because these tires are 3 inches overall bigger than the stockers and i already had a few marks where the factory tires rubbed above them.
Also i got the blocks and U-bolt from
http://www.trailerblocks.com/
A little pricey but great quality!
Thanks. Those blocks are a little pricy considering they're just a chunk of bar stock. I guess you had to also raise the hitch head 2" to keep things level?
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
dodge_guy
What is the LR of those LT's? I was looking for a set of LR "E"'s for my trailer but couldn't find a set in A LT.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
KVE777
Lynnmor wrote:
Any reason why you didn't use Goodyear Wrangler HT LT215/75-15?
I was lucky enough to find a pair of those used for a utility trailer that frequently hauled heavy loads, like half a roof's worth of shingles! Never an issue. Way better than any ST tire. Radial LT Load D or E are the way to go.
ChuckNTruck
I honestly didnt see those when i was looking. I was having trouble finding anything smaller than what i got in a highway tread and i wanted a tire that i could replace if i do have an issue on the road.
Ill have to keep those in mind in case anyone ever asks me about swapping.
I like that the Goodyears you pointed out are actually a D range also.
Thank You!
Lynnmor
bobndot
Nice job Chuck and a worthwhile mod, tnx for taking the time to post the pics.
ChuckNTruck
hohenwald48
Was 2" lift necessary or did you just want the additional ground clearance?
Huntindog
Good job.
Where did you get the lift blocks? I am using solid steel custom made ones, just because I couldn't find any.
It appears that you could fit 16s if you wanted to... Would need new drums and rims though.
Huntindog
100% boondocking
2 bathrooms, no waiting
17.5LRH commercial tires
tvman44
Good job, I put that same spare tire carrier on my 5er & love it. ๐Ÿ™‚
Papa Bob
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
nevadanick
Nice
