โJul-04-2020 07:20 PM
โMar-18-2021 07:42 PM
crosscheck wrote:bpounds wrote:crosscheck wrote:
One of the main reasons I chose a Danfos compressor style 12V fridge /freezer was because the they are a favourite of the ultimate boondockers which are yachters....snip
Using 12VDC is by far the least efficient way to generate heat, out of the 3 utilities common on RVs.
That's not to say it isn't appropriate in some situations. You mentioned one.
If you've got enough solar and battery bank to support it, more power to you. I've noticed there isn't much shade over sailboats.
I have seen a 12vdc fridge run our truck battery down during a single overnight stop at a motel. GM truck, which did not isolate the trailer from the starting battery. So it depleted the trailer battery and the truck battery. I wasn't the owner, but I was a participant, and it was my AAA card that got us back on the road that morning.
"Compressor Refrigerators
They use a process that compresses refrigerant to draw hot air out of the food compartment and vent it out the back or top of the fridge. They are highly efficient compared to absorption refrigerators." These are not my words but taken from a technical article regarding RV's. Compressor fridges do not use heat to make cold like absorption fridges do, that is why they are more efficient in energy use. If you are set up for high efficient compressor fridges, they work much better than absorption fridges. Just read all of the posts by big rigs who are turfing their Norcold units for compressor fridges.
One last thought, as most modern houses/apartments/businesses have natural gas and could have absorbtion appliances for cooling/freezing, why is compressor technology used in fridge/ freezers in 100% of domestic and industrial applications throughout the modern world?
Check out our blog when we had our previous rv an Outfitter TC for 5 years. You will see our camping style is "dry" with very few times using genny or shore power and our compressor fridge was never a problem regarding running down the batteries.
Dave
โMar-14-2021 09:08 AM
โMar-14-2021 08:50 AM
crosscheck wrote:
One of the main reasons I chose a Danfos compressor style 12V fridge /freezer was because the they are a favourite of the ultimate boondockers which are yachters. They can't use propane fridges because propane is heavier than air and could sink to the lower decks if there was a leak and could cause an explosion.
Dave
โMar-13-2021 07:12 PM
Huntindog wrote:
Do you think those fans would do as good a job circulating heated air thru the underbelly as the furnace fan?
I agree on not using a non vented heater... Even when not planning to sleep. Sometimes those heaters can make one sleepy.
I do use the generator though. It is 75' away, usually behind a tree/fallen log etc.
โMar-13-2021 01:33 PM
pianotuna wrote:Do you think those fans would do as good a job circulating heated air thru the underbelly as the furnace fan?Huntindog wrote:
Probably with some creative modding it could be made to work... BUT it probably would be a waste of time. The reason for a CAT heater is to eliminate the draw from the fan. Installing a fan that would move enough air to make a difference would put you back where you started from.
My twindow fans draw a scant 27 watts and solved water line freeze ups. I used them to replace the return air grill for the furnace. I operate them using a mechanical thermostat kept near the water pump.
I won't use a non vented combustion heater, nor a generator when I plan to be sleeping.
โMar-13-2021 01:29 PM
GravelRider wrote:
I installed the battery monitor today, so I'll be able to get a much better picture of how much battery I'm using and how much each item is drawing.
โMar-13-2021 12:33 PM
โMar-13-2021 08:02 AM
โMar-13-2021 02:46 AM
CavemanCharlie wrote:Probably with some creative modding it could be made to work... BUT it probably would be a waste of time. The reason for a CAT heater is to eliminate the draw from the fan. Installing a fan that would move enough air to make a difference would put you back where you started from.Vintage465 wrote:crosscheck wrote:Vintage465 wrote:crosscheck wrote:bpounds wrote:
Couple things to add,
That 12v fridge is bad news for boondocking. They are very inefficient. Normally only find those in popup style rigs. But, I guess you're stuck with it. Get more battery.
I like the Vmax line of 6vdc. And with those AGM, you do not need to put them in a battery box. They are safe in any orientation. That might allow you to get even more than 2 of them, but you do need pairs. Unless you look at the Vmax 12vdc AGM. I don't have the 12v, but I would trust the name.
The cheap club store batteries will need to be in a box, and you'll likely end up replacing them sooner. Depending on how you maintain them. Might or might not be worth the savings to you.
Our camping style is 98% dry/boondock camping. For 5 years, we camped with a 7.5cuft NovaKool fridge/freezer which when cycling used 4.4A. They are more efficient than absorption fridges using 1/3 less energy. They cool much quicker, for the same outer dimensions, have 1/3 more volume, keep more consistant temperatures in hot ambient temperatures and are not a fire hazard. We almost never needed our 2000W genny as we had 4 6V AGM batteries and lots of solar.
People who use the term"12V fridges are bad news for boondocking" have never had this kind of fridge. They are becoming much more popular for so many reasons as long as you figure in more electrical capacity(batteries, solar) if you don't want to run your genny.
I have a 6 cuft absorption fridge in my TT which came with the new unit. If it gives up the ghost down the line, a 9 cuft NovaKool will fit exactly in the same opening and as I already have plenty of solar and 4 6V GC-2 batteries and more room for extra solar, this is the route I will go.
Dave
That does sound like an efficient 12v fridge. My concern as a boon docker is I hate.........did I say hate?.... Generators. I'll do most anything not to use a generator. And I like camping year round. That include weather that gets down in the teens. I'd need enough battery to run my furnace to heat the the belly of the coach to keep the tanks warm enough. I can keep up with my furnace pretty easily with my solar, but I think if you tagged another fairly high draw unit on the 4-6v's it'd get critical. Bottom line is you really have to prioritize your usage choice. I want a furnace, a C-pap, no genny and winter. Prolly nixes the 12v fridge...for my boon docking needs.
Howdy, to another Creekside owner. Another neat plus for compressor fridges is that they can be operational without problems out of level for long periods of time.( Again, think of yachts).
No question, the NovaKool was the largest single draw of battery power bar none.So if you had to choose, get rid of the OEM heater fan and put in a Cat heater. I have no experience with these but some say they work well.
My absorption fridge works fine but I would replace it in a heart beat if it quit.
Dave
Problem with the CAT heater will not heat the belly in real cold weather. I personally am big fan of propane fridges. I don't see any reason to use anything different. I've also found, as I get older, that there are an alarming number of people that really don't care what my opinion is! Everyone will use what they need that fits their use needs.
Sorry to jump in on the middle of your conversation. Could a person use a CAT heater and a 12 volt fan to push heat into the underbelly ? I've often wonder d about this.
I too love my propane fridge that I have in my 1993 Travel Trailer and I have no problems with it cooling.
My brother has a 2018 5th wheel and the propane fridge that he has will not keep food cool when he is traveling down the road, or in days when the outside heat is high. I think the newer ones are not built as well and are giving the whole industry a bad reputation.
โMar-13-2021 02:42 AM
GravelRider wrote:I have a 18 CF propane fridge that works great.
โMar-12-2021 08:35 AM
โMar-12-2021 06:03 AM
pianotuna wrote:
Here is some more detailed information on SiO2 batteries:
***Link Removed***
โMar-12-2021 06:00 AM
โJul-13-2020 08:18 PM
bpounds wrote:
I have agree with Vintage465. My propane ain't broke, and it don't need fixing. It is perfect for boondocking.
I get it though. Absorption fridges are kind of a pain at times, for some people, and the urge to go with a residential fridge is strong. All kinds of ways of justifying a residential unit in an RV have been posted. Now that solar and lots of battery are all the rage, some have lost interest in efficient off-grid practices. Just throw juice at whatever inconvenience comes along. Okay as long as the weather stays clear and sunny.
Whether it runs through an inverter, or directly on 12v battery, a residential fridge is what it is.
