TC solar panel question
Geewizard
I have a permanent solar panel on my TC and am adding a second portable solar panel for use on the ground.
Question for those of you who have done this: did you buy one or make an adjustable frame for your panel? If so, how?
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
8 REPLIES 8
Geewizard
Indeed it will. Just move it around on the ground so it points at the sun.
tuna_fisher
Geewizard wrote:
An update to this posting!
I found this Adjustable Solar Panel Mount Mounting Rack Bracket on Amazon.
It's just the thing for my application.
Will these work to tilt both ways depending which way your parked?
2001 GMC DM, 1995 Lance Lite, @005 Eclipse Toyhauler, Toy's!;)
Geewizard
Geewizard
thanks all.
I bought this solar panel and will wire it in parallel with my other panel to the MPPT controller.
errante
I personally use a flexible panel to augment my 200 watts. The advantage is that I can tie it off anywhere on the camper to find sun. I just use an extension cable to reach a dc jack. It is low wattage panel so no controller necessary. If I had the room I would consider the harbor freight 45 watt panel kit. The sku is 68751, priced at $199.99.
tonymull
Keep in mind that you usually don't have to tilt them much. On the other hand the farther north you go the more tilt you may need, especially if you're looking for that late afternoon sun. I remember once in BC standing a panel up against a picnic table to glean the last hour our two of sun to top off my trolling motor battery. I was surprised at how much power it still produced.
Fishbreath
I have made two. Both times I made an "A" frame out of aluminum (angle iron). I made them so the stand would fold flat against the panel for easy storage.
I love the moveable ground panel. Although you will need to move it a couple of times during the day, you will be surprised how much extra energy you can get out of it.
Good luck with your project
Bill
RoyB
Someone last week was saying they used one of these folding step stools to support their portable solar panel...
Sounds like a neat idea too me...
$12 AMAZON
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
