Tekonsha - Internal Error - No brakes
ugh
I just went to my truck today and saw my Tekonsha Prodigy 3 displaying a warning message that says "Internal Error - No brakes" I just checked the internet and it does not answer my question. Has anyone seen this before? Yesterday it was fine. It rain like crazy over night and now I see this. Could something got wet? Any Idea before I disconnect it to reset it and cross my fingers. Last thing I want is this to go out when I am on the road towing the camper.
2001 F250 5.4 3.73
2015 Wildwood X-Lite 262BHXL
10 REPLIES 10
bikendan
BrentB wrote:
I'm getting the same error message. Sometimes unplugging it will help, sometimes not. Seems to be getting worse. Did yours keep working or did you end up replacing it?
You re-awakened a 5 year old thread. The OP may not be around anymore.
BrentB
If you have one of these products, make sure you keep track of the original sales receipt. Without that, there is no warranty whatsoever!
Sjm9911
https://www.etrailer.com/question-31166.html
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
BrentB
Greentreena
I have had to do a complte reset before which meant unpluging it from the truck. That fixed the issue. The other problem I've encountered it the 4 pin trailer connection under the bumper got corroded (from complete lack of use) and caused a short to display on the controler.
2008 Dodge Ram 3500 6.7 Mega Cab 4x4 SRW Laramie - Big & Black
Full delete, Torque Technolgies programmer, Sinister EGR delete
Hijacker Auto Slide/ P3
2006 Triple E Topaz 310RBXL
Wife, 2 kids (Murphy the dog - RIP friend)
ugh
I just remove it, so I can get the product and serial numbers to call them. They kept putting me on hold for technical support and I waited a long time. I tried call theming several times with same results. I gave up and put the brake controller back in the truck. Its fine now and it is not displaying any error message. I guess the rain may had short it out. I will look at it this weekend to see where this could be happening.
2001 F250 5.4 3.73
Majja13
And you could have a short in the wiring that is why the message no brakes. Dry it out and make sure you do not have any worn sires that the water could be closing the circuit between and causing a short.
2015 GMC Sierra 2500hd 6.0 w/4:10 rear end
2006 SkyLine Weekender 180
1200/12000 Equal-i-zer WDH
Campfire_Time
Lifetime warranty, so don't hesitate to call them.
Chuck D.
“Adventure is just bad planning.” - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
katoom400
take it to any dealer, they have a lifetime warranty. I had my p2 for over 10 years and went to a trailer supply store expecting to buy a new one when mine wasn't working and the guy looked at it, went inside and came out with a new one in the box, plugged it in and sent me on my way...free of charge...I didn't even buy it there originally!
hawkeye-08
They have great customer service, a quick call to vendor and you'll have best answer.
