the same drain hose for the TT kitchen sink and TT toilet?
thehippie
Wud it matter u use.the same drain hose for the TT kitchen sink and TT toilet?
8 REPLIES 8
Ron_Schulz
Are you asking about the slinky for the outside dump valve? Than yes, that's fine. If your trying to conjoin the plumbing inside the RV, don't do it...
Ron & Sue Schulz, fur-child Lilly
Proud Army Dad
US Navy/Vietnam Vet.
Retired Service Tech- 34 years
thehippie
Thanks for all ur replies.
cbshoestring
Triker33 wrote:
Always dump the TT toilet first and the TT kitchen sink last
X2....
Stinky stuff first, followed by a soapy "clean" dump that helps to clean the hose. I typically go back to the black (weight shift on trailer gives a bit more) then hit the gray a 2nd time as well.
Dick_B
I think we all use the same drain hose BUT the usual procedure is to dump the Black Tank then rinse out the hose with discharge from the Gray Tank(s).
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Triker33
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
valhalla360
Nomad III
Nomad III
Are you doing something unusual with the drain? Most come from the factory set up to use a single drain.
Way back (as in a few decades), it wasn't uncommon to dump the gray water on the ground but it's been a long time since that was considered acceptable. You may have a seperate gray water tank but that is more a convienece for plumbing as the kitchen sink may be well removed from the toilet, so it's easier to set up a second tank close to it and then plumb the outlets together.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Old-Biscuit
Nope........
It's all WASTE water.
Not like you are reusing it for anything....but then again you have asked some doozies in the past :H
Houston_Remodel
Most trailers have a single, joined grey and black output using a single hose. It matters not.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
