This could be bad for GM
ib516
Feds Probing 2.7M GM Trucks and SUVs Over Braking Issue
LINK
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
5 REPLIES 5
theoldwizard1
garyemunson wrote:
Thought the hydroboost system was the choice for Diesels.
Hydroboost is expensive and not a "perfect" solution either, especially since more and more vehicle are going EPAS (electric power assist steering).
KansasBill
Jimnlin wrote: {...}
Took it to one of my chevy dealers and complained. Mechanic says their seeing this a lot. Service mgr says he hadn't heard anything on the issue. :R
Hmmm, ServMgr must be related to Brooks & Dunn: “Deny, Deny, Deny” :B
2012 Ram 2500HD Crewcab, 6.7L Cummins, 6spd auto, short bed, 4WD
2006 HitchHiker II LS 28.5 RLBG two slides
Reese 16K Fifth Wheel hitch w/Kwik-Slide
JIMNLIN
Twice the wifes 2016 chevy 1500 5.3 crew cab short beds brakes went away at idle while making a multi point turn around in a crowded parking lot.
Both times the engine was at idle. Both times I got it in neutral/park quickly and run the rpms up. Brakes came back.
garyemunson
Had no idea they went back to using vacuum for power brakes. Thought the hydroboost system was the choice for Diesels. The old GM Diesel car engines used hydroboost for the brakes but had a vacuum pump for the A/C controls. Those always failed early, hydroboost always worked. Ford gas F-53 Class A chassis use hydroboost.
SidecarFlip
Vacuum pumps wear out over time, just like anything mechanical does.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
