Timbrens, Stable Loads or both??
Mattyd
My '13 Ram quad cab dually 3500 4x4 handles my NL pretty well until I have a full fresh water tank and half full or better gray and balck water tanks. Then she gets a little roly poly particularily at slower speeds. So by TC brethren, would you add Timbrens, Stable Loads, or both? Anyone been here, done that?
2016 AF 990
2013 Ram 3500 Dually, Crew Cab, 4x4 CTD
Hellwig Rear Anti-Sway Bar
Torklift StableLoads & Fastguns
2014 Rubicon Unlimited
7 REPLIES 7
MORSNOW
Navigator II
Navigator II
I would recommend adding the lower Stable Loads. They will help greatly with your sway as they add the overload spring to your spring pack all the time.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD 7,220# Truck/10,400# Camper Fully Loaded
starcraft69
I went with tembrens and rancho 9000 Took almost all the sway or rocking out. I now can drive 75 mph ( but I would never do that) lol
2007 chevy 2500 HD 6.0 longbed
2015 Eagle HT 28.5 5th wheel
tucker the fishing dog
Bedlam
Moderator
Moderator
Mattyd wrote:
Fellow at the TC dealership suggested doing the lowers as they were more effective.
The lower StableLoads worked great on my F250 and were easy to install since my lower springs already had holes. Torklift has a tool rental/borrow that makes drilling out your springs easier.
ejfranz
I went with the Timbrens and KYB mono max on the rear. Great improvement, but my truck was 6 years old when I did I it and the stock shocks were shot.
06 Chevy Silverado 3500 Crewcab SRW 4WD - Allison 6 speed & Duramax LBZ.
Upgrades: BD diesel exhaust manifold, Edge Evolution, Timbrens & KYB Monomax.
Camper: 2005 Adventurer 90FWS - Electric jacks, LEDs, 6V batteries, roof rack, ladder & awning.
Mattyd
Thanks Bedlam, forgot to mention stabilizer bar has been added as well as upper Stable Loads. Fellow at the TC dealership suggested doing the lowers as they were more effective. As far as air pressure being low, you are correct once the inside dual was low. I thought what the heck, why is this handling so funny. Stopped about 5 miles up the road and sure enough. Low tire. Aired it up and no more puroblem.
2016 AF 990
Bedlam
Moderator
Moderator
Adding a stabilizer bar and making sure the rear tires are fully inflated will also help.
JohnAM
I would add stable loads first and see how you like it. I think that will take care of your problem. The only other upgrade to consider is aftermarket shocks. Made a big difference to me, though my truck (06) had 60K miles when I did that upgrade.
2011 RAM 3500 CTD Laramie DRW 4x4, Torklift, Superhitch, Stableloads
06 Dodge 3500 CTD Quad DRW 4x4 6sp Man, TorkLift, Superhitch, Stableloads, KYB Monomax (Traded in)
11 Lance 1191
97 Lance 980 (Sold)
