โJul-18-2015 12:54 PM
โJul-27-2015 08:34 AM
โJul-25-2015 07:17 AM
โJul-24-2015 09:08 PM
โJul-24-2015 11:31 AM
โJul-23-2015 09:38 PM
โJul-23-2015 11:34 AM
โJul-21-2015 10:13 PM
โJul-21-2015 09:59 PM
โJul-19-2015 02:49 PM
โJul-19-2015 07:33 AM
โJul-19-2015 05:12 AM
What are the main differences between P, LT, and E tires? How come you prefer LT tire over E tire? Are the E tires taller and befier in general? Or just have thicker walls?
โJul-18-2015 07:07 PM
polishpickles wrote:
This is what the sticker says:
GVWR/PNBV 2132 KG
GAWR/PNBE FR. 1082 KG
With P225/70R15 tires 15x7.0 rims at 30 psi, cold single
GAWR/PNBE RR. 1202 KG
So that's 4700 lbs. in total. But is "GAWR/PNBE RR 1202 KG" the rear axle max load? That would be around 2650 lbs. In that case would I be just under? Camper @ 1100 lbs, passengers gear and others at 800 lbs?
Thanks.
โJul-18-2015 06:15 PM
โJul-18-2015 05:52 PM
Gotcha. That will be the next step I guess. What happens if I'm over the max load?
