May-21-2015 11:14 AM
May-26-2015 04:28 PM
May-24-2015 01:33 AM
45Ricochet wrote:
Just My Opinion Ron but those new ones won't last either with that pressure. Your center belts are taking a beating from over inflation. Pretty sure I know tires, ask Chris where he bought his Duravis R250's tires from for his RV. :W
And you didn't mention male baldness pattern :B so I assume I struck a nerve :E
May-23-2015 08:20 PM
May-23-2015 05:16 PM
May-23-2015 03:33 PM
rhagfo wrote:Cummins12V98 wrote:soje wrote:
5 th wheel tow vehicles (Single rear wheel):
What is your favorite LONGEST WEARING TIRE?
Looking at my 265-70-17 Michelin LTX M/S 2 , I am disappointed with the amount of wear from towing. Minimal/normal wear on front tires,
rotate every 10k 80 psi etc..............
Tires have 3 center 7/8 inch WIDE ribs with a 1/2 inch space on either side(4 total)--NOT MUCH RUBBER ON THE ROAD FOR A TIRE THAT WIDE. Maybe that accounts for the wear under the pin weight?
Not pleased with the LTX tires..............
Following a 9,000 mile + trip there was significantly MORE wear on the drive tires than the steer tires.
SO what are your recommendations for a longer wearing tire? What tires have given you the best wear?
TV-04 Ram cummins 3500 SRW-Ft xl weight-3900, rear xl- 5000, 12,000 5er
You are running WAY too much air pressure! Since you know your weights use the weight/inflation chart for your tires. Add 5psi to what the chart says.
X2!!
Your tires are rated at 3,195# ea. at 80 psi. That means at 80 psi you have 6,390# of capacity, carrying 5,000#. That is about 80% of capacity, you are running overinflated.
I run between 65 psi to 70 psi in my rear tires with a 5,500# rear axle GAW Towing. When not towing I run about 50 psi in the rear, better wear and great traction.
May-23-2015 03:23 PM
45Ricochet wrote:
Just me but 80 is about 15 PSI to much on your fronts. Clearly the center sipeing is almost gone and the outers are in fine shape. Surprised the side walls lasted that long though from what I've read :W Hey now that I look at it your outside rear is showing almost the same pattern.
They kind of look like a male baldness pattern :B And I know hair buddy.
May-23-2015 12:59 AM
May-22-2015 09:50 PM
May-22-2015 07:55 PM
May-22-2015 07:23 PM
May-22-2015 06:57 PM
May-22-2015 06:03 PM
May-22-2015 05:58 PM
May-22-2015 05:42 PM
45Ricochet wrote:
Bridgestone Duravis R500 HD. Not real good in Winter though.
