TMPS Booster Placement
Bryanpark2
I would like to see how others have connected their booster for the Tire Pressure Monitor. I would like to attach directly to my TT battery but the alligator clips are to small to use the battery posts.
2013 Jayco Jayflight 26RLS
2011 Trundra 4.6 V-8
7 REPLIES 7
Lynnmor
guidry wrote:
I placed the receiver suction cup holder on the inside back window of my truck and found I didn't need the booster. Whn it goes off I can see it in my rear view mirror and pull over.
With my old ears, I can barely hear the alarm when it's right in front of me.
Lynnmor
Esacnj wrote:
I did what Lynnmor did except I connected it ahead of the light switch.
The switch I used is center off. Turned one way the light is on, and the other way the repeater is on. This way, I can easily turn off the repeater when not in use. Of course a switch can be added on any supply line.
guidry
Esacnj
Esacnj
TucsonJim
Great question. Following this thread because I just received a booster from TST myself.
Jim
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
RoyF
I found a small recharable 12v battery at Radio Shack which worked for me when I used Pressure Pro.
(But after switching to TTS, I no longer need to use a booster.)
Lynnmor
I put mine in the front storage area and connected to the back side of the lamp in there. I replaced the switch with a ON-OFF-ON switch.
