Took the plunge - Cummins to Hemi 6.4
nirion
After reading posts, reviews, specs, watching videos, and a few test drives, I finally decided to take the plunge. I sold my 2003 Ram 2500 QC LB 4x4 Standard output 5.9 Cummins 5 speed and bought a new 2014 Ram 2500 Big Horn CC LB 4x4 Hemi 6.4 with 4.10 gears in Western Brown.
It has the 5th wheel prep, so I had to order a new base for my B&W companion hitch. It should be here Friday and I hope to do some test towing this weekend. We leave for our first big RV vacation soon, a trip to Disney's Ft Wilderness on 10/18. I'll post back with more info after the test pulls and hopefully a trip to the scales.
Thanks to all, but especially ib516, for the info on the 6.4. I went back and forth between 3500 SRW Cummins or a Hemi 6.4. I really hope I made the right decision. 🙂
2016 Ram 3500 SRW Big Horn CC LB 4x4, Cummins Turbo Diesel, Maximum Steel
2015 Sprinter 324FWBHS
2014 Ram 2500 Big Horn CC LB 4x4, Hemi 6.4, 4.10 - SOLD
114 REPLIES 114
katoom400
blderman wrote:
ib516 wrote:
blderman wrote:
Have you guys watched the Ike Towing Test posted this weekend? I have no idea how credible the testing guys are but I was pretty disappointed in the results. It's making me second guess the 6.4 now. The F150 Ecoboost towing just 1,800lbs less made it up the hill 4 minutes faster than the Ram. It appears the 2nd gear ratio on the 6.4 is really a poor fit for the engine. Thoughts?
You have to read the comment they posted a couple hours ago. They contacted RAM about the results, and got this response:
"We spoke with Ram and here's what they said about the slower Results of this Ike Gauntlet Run: "During the Silverado drive, you spoke negatively of the shift calibration. The tested Chevy was we assume hunting between 1st and 2nd, and ranged from 5300erpm to around 2800erpm, which you didn’t seem to like. The Chevy revved very high up the hill for extended periods of time, over 5000erpm.
Ram Truck “invented” the first gear hold feature – and calibrated it – to avoid gear hunting and driving at excessively high rpm’s.
Ike is a variable grade and we worked hard to develop a calibration that appropriately manages torque on the run and other grades.
We don’t want the truck to rev high for extended periods of time and purposely hold 4,200 rpm.
Bottom line – our truck performed exactly as expected by delivering a more comfortable hauling experience, better vehicle longevity and improved fuel economy. Time to the top of the hill is only one small piece of the driving experience and our engineers take a number of variable into consideration. Ask yourself if just over one minute is worth other negative driver inputs."?
I haven't experienced any limiting in any towing I have done, but then the highest elevation I have been to so far is about 7000'.
That is the response I would expect from an engineer. It's not like they are going to admit that 2nd gear is the wrong ratio. This definitely has my plans on hold till I can do more research. It would be interesting to see how it performs in manual mode.
would you really say 2nd gear is the wrong ratio, or is the shift logic a bit off?
Really, would you allow your truck to climb steep incline like that? I know they had to keep all things as equal as they could for the test, but in the real world, are you going to let the truck slow down to 30mph? No! you are going to manually downshift and let the truck rev! The Chevy was certainly at 5k for long periods of time, and that is most likely why it got to the top faster.
A more accurate test would have been to set points along the route where you designate down shifts for both trucks and see how they fair. the fact that the Ram held second for far too long doesn't bother me because I would never have let that happen in the real world.
IMO the only thing you could knock the Ram for is failure to downshift on an tough grade. BIG DEAL!
oh, one more thing for the guys bashing the Ram, watch the Chevy video @ 19:45 they start talking about how the truck should have downshifted and is holding the gear for way to long and they are down to 35mph.
So I would say if you have no clue know how to drive a truck pulling a heavy trailer, you would be better served buying a Chevy as it will downshift for you in case you fell asleep.
and no I'm not a RAM lover, I'm a Tundra guy looking at all the options for my next truck and I really think all of the big 3 are so close you just have to pick the one that appeals to you or fits your needs the most and you can't go wrong.
blderman
1 DW
2 DS
1 DD
Jayco 23BHS on order as of 3/19/15
2014 F150 SCREW LB 4x4 Ecoboost Max Tow (Beats my 02 7.3 PS hands down)
Can't wait for bow season!
Bedlam
Moderator
Moderator
blderman wrote:
I would like to have the maneuverability of a short bed, but an 8' bed is nice for so many reasons that I don't think I could go back.
I love the handling and maneuverability of my short bed extended cab. I recently pulled the camper off since I am putting this one up for sale and have been driving it around more. I can get close to that with an extended cab F550 because the wheels cut sharper even though the bed would be longer: 6.75' to 9'. Most likely I will be going from my 19.25' truck to something closer to 24' and give up some of that nimbleness.
colliehauler
bucky wrote:
Sweet truck. I currently tow with a CTD but agree with comments about the initial expense and the increasing complexity of the emission era diesels trucks of all brands. I have an older truck with a Banks kit on it, so I'm at approx 325/650. A bone stock 24V would be a dog.
I would suggest getting at least 500 miles on it before you tow. That will seat/condition the ring and pinion properly and give a longer life. Towing too soon can wreak havoc on an axle.
As others have mentioned, that thing has to rev, don't let the noise scare you pulling a grade.
I will second the 500 miles to seat the ring and pinion before towing.
ib516
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
blderman
larry barnhart wrote:
FLT has a new 6.4 towing test on you tube.
chevman
I posted that on here earlier today. Seems the test is deceptive since the Ram was carrying 2,000lbs more than the Chevy. I still don't like the 2nd gear on the Ram though.
1 DW
2 DS
1 DD
larry_barnhart
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
blderman
katoom400 wrote:
I'm looking at a 2014 2500 with 4.10's got the dealer down to ~$35k from the 43k msrp before taxes and tags. I found some on autotrader.com at a distance away that looked attractive at ~$31k but as mentioned by another poster, once they take away all of the incentives that I'm NOT eligible for the price is about the same as my local dealer....I'm pretty set on 4.10 gears and the 6.4, now to decide 6' vs 8' bed!
after having had the 8' bed on my Tundra I'm not sure I can go to the 6.5' bed but with the Ram the long bed version ~1' longer than my current dual cab tundra...which barely fits in the garage...it might actually be nicer to have a truck that is 1' shorter if I can deal with the loss of bed space.
1 DW
2 DS
1 DD
katoom400
kmbelt wrote:
3.73. Wish they were 4.10's.
crcr
kmbelt wrote:
running at 55, i get around 17. on the highway at 70, i get around 15-16.
Are those figures hand-calculated or from the onboard computer?
kmbelt
katoom400 wrote:
kmbelt wrote:
I had a 2009 GMC 2500HD, CC, 4x4, 3.73 with the 6.0 and 6-speed tranny. It was gutless compared to my 6.4 Hemi. I'm towing the exact same trailer loaded pretty much the same way and traveled the exact same 1500mi route as my trip to Fl last week.
I could NOT use cruise control in the 6.0 as it constantly shifted down to as low as 3rd. My 6.4 hardly ever shifted in and out and only went to 3rd a couple of times.
what gears are in your 6.4?
2014 Ram 2500, 6.4 Hemi, CC, 4x4
2010 Puma 259RBSS
katoom400
kmbelt
2010 Puma 259RBSS
blderman
Looking into this more closely it appears some unintended deception might be taking place. The article says they loaded them to within a 100lbs of GCVW but they don't mention that the Ram has a 2,000lb higher capacity than the Chevy. That is a significant weight difference to carry up a steep grade while losing up to 30% power near the top. Seems to me like the test should have involved equal weights.
1 DW
2 DS
1 DD
blderman
katoom400 wrote:
although, I don't think they mention what rear gearing it has?
They both have 4.10
1 DW
2 DS
1 DD
