tow capacity
tuctam
I know you are all probably tired of answering these same type questions but the more I study this the more I am getting confused.
We are "playing" with the idea of upgrading to a 32ft, 3 slide TT.
Dealer says 8520 GVWR and 2350 dry weight.
We drive a 2005 350 Ford Turbo Diesel V8. The sticker info on the truck door says front GAWR 5600lb Rear GAWR 7000lb and GVWR 11,400lb.
We recently added the bullet proof kit to the engine.
Everyone is telling us this TT wouldn't be a problem but I am not feeling as confident from everything I am reading. Can I get some help to get through my confusion with some experienced advise.
Thank you!
18 REPLIES 18
Old-Biscuit
You won't even know it's back there :B
2005 F350 DUALLY is more then capable of towing that travel trailer.
You've already addressed the real concern''''that 6.0
2005 Ford Tow Guide....pg 17
Have fun....enjoy!
Go Camping
lenr
Folks tow that size trailer with big gas engines all the time and OP has a diesel! He would have to load it VERY heavy in the bed to be over limit. GCRW is important but even that will be hard to exceed without some really heavy loading.
BenK
Welcome to the forum !!!
First, decide if you believe in the OEM ratings system, numbers, recommendations, etc...or not
If not, then do whatever and note that you assume the liabilities
If yes, then learn how that ratings system works, which includes 'recommendations'...that so many think does NOT matter. They do not understand that if you do not follow the OEM's recommendations...that OEM may no cover any warranty or liability
Those TV ratings you list are for the maximum conditions (weight) to the pavement when your TV is loaded. Including the trailer PIN/Tongue weight
The MTRW (max tow weight rating) of your TV by its OEM is derived from a 'curb' TV (stripper model) with only one option (tow option), one 150 lb driver and fluid tanks filled to whatever (some half full, others 1/4 full...to full) and one 150 lb driver. NOTHING else in/on the TV
Also, know that many confuse 'can' vs 'rated for'
Find your TV's GCWR (fairly new rating and many do not understand, nor believe in it) and do the simple math:
GCWR >= TV weight + Trailer weight + stuff
'Stuff' as in all the people, pets, cargo in/on the TV, WD Hitch system, options (factory and after market).
Best to load up your TV ready to tow and weigh it. That will then provide the actual weight for the above formula that will tell you what the actual MTWR is
Good luck !
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
lawrosa
Be more specific on the truck and trailer weights. Your typing skills are a bit confusing..
Truck model.
Trailer model GVW TW etc
Payload capacity of truck.
( Probably best going to scales so you know exactly what your dealing with.
The lowest tow weight for your truck from the guides is 11700.
I dont see an issue so far as I am sure you have enough payload.
But who knows.
First # is tow rate 4wd, second is AWD and third is GCWR
http://www.trailerlife.com/wp-content/uploads/2012/01/Trailer-Life-Towing-Guide-2005.pdf
F-250/350 SRW Reg Cab
5.4L V-8 12,000
6.8L V-10 (a) 12,500 (17,000/16,500) 23,000
6.0L V-8 TD 12,500 (16,500/15,900) 23,000
F-350 Reg Cab DRW 5.4L V-8 12,300/11,800 18,500
6.8L V-10 15,000 (16,700/16,200) 23,000
6.0L V-8 TD 15,000 (19,200/18,700) (b) 26,000
F-250/350 SuperCab SRW
5.4L V-8 11,700/11,200 18,000
6.8L V-10 (a) 12,500 (16,600/16,200) 23,000
6.0L V-8 TD 12,500 (16,100/15,600) 23,000
F-350 SuperCab DRW
5.4L V-8 11,900/11,400 18,500
6.8L V-10 15,000 (16,300/15,900) 23,000
6.0L V-8 TD 15,000 (18,800/18,400) (b) 26,000
F-250/350 Crew Cab SRW
5.4L V-8 11,500/11,100 18,000
6.8L V-10 (a) 12,500 (16,400/15,900) 23,000
6.0L V-8 TD 12,500 (15,900/15,400) 23,000
F-350 Crew Cab DRW
6.8L V-10 15,000 (16,100/15,600) 23,000
6.0L V-8 TD 15,000 (18,700/18,300) (b) 26,000
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
