Aug-05-2019 03:53 AM
Aug-05-2019 02:52 PM
ShinerBock wrote:What he said....no magic, it's designed to make towing easier on your transmission. No reason not to use it.
The TC clutch does not release even in normal mode as you slow down until you get down to a certain speed. Tow/haul lowers this speed threshold. The main thing tow/haul does is change shift points. It holds gears longer when up-shifting to keep you higher rpms for more power. This is better for your transmission when towing. It also downshift earlier when decelerating to help slow down the vehicle quicker. This is not good for your transmission, but it is not that bad either.
Another thing that some transmissions do in tow haul mode is increase the line pressure threshold. This changes the shifts from nice smooth shifts to more firm shifts. This is good for your transmission because it decreases clutch wear and creates less heat due to decreasing the amount of time the clutch slips at each engagement/shift.
Aug-05-2019 02:34 PM
Aug-05-2019 12:25 PM
Aug-05-2019 12:08 PM
Aug-05-2019 11:08 AM
kellem wrote:
I use tow mode and OD off every time I tow.
Less shifting = cooler transmission.
Aug-05-2019 10:14 AM
Aug-05-2019 08:53 AM
Aug-05-2019 08:28 AM
Aug-05-2019 07:49 AM
Aug-05-2019 06:55 AM
Aug-05-2019 06:38 AM
