Towing 9,500 Pounds with 3.31 gears
Kampfirekid
Looking for experience here. Found a nice deal on a 2013 Superduty with the 6.7L smoker. If it comes together, I'll say goodbye to my 6.4L Harley. The new rig has the 3.31 electric locker. I'm hearing with the diesel, it doesn't matter much towing under 10k - especially with the 18" wheels. Since I will daily drive this truck, I want the economy of the 3.31 rear with 18's. My dad pulls 18-20 continually with his 6.7L, and I'm sure it's the 3.31. Will this hurt me? Remember, I tow the Midwest. Hills, not mountains. The Flight is probably 9,500# on a bad day. I'm thinking I may have to get on it to move the load at first, but that's it. Thoughts?
2019 Ford F-150 Lariat Supercrew. 5โ€“/2 foot bed. 3.0L Powerstroke,
Loaded. 2020 K-Z Connect SE 241BHKSE
11 REPLIES 11
wmoses
Kampfirekid wrote:
Thanks everyone. Pick her up tomorrow or Monday. 3.31 it is!
Good move. Enjoy!
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
Kampfirekid
Rjdreyer
Recent Ford diesels come with two axle ratios, 3:31 for 18 inch and 3:55 for 20 inch tires.
45Ricochet
Your good, enjoy it.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
wmoses
OP, I would bet that you will have no issues whatsoever. Like someone alluded to, the pulling capability does not only depend on the rear differential gear ratio given the modern 6-speed transmissions. It is the combination that counts. And torque (as opposed to horsepower) which the new Ford diesels have torque in spades.
The 2013 Super Duty is not a "smoker". Beautiful efficient engines, no smoke as far as I have seen.
If I had the money right now that would be my choice, although the 2015 GMC Sierra 2500 HD is also very interesting, but it would have to be competitive with the Ford on both price and feature combination I would want. We'll see in early 2014 when it becomes available.
Regards,
Wayne
_
jerseyphil
I have a 2011 F250 diesel with the 3.31's. I tow a Keystone Cougar 318SAB. I know it is over 10,000lbs loaded up and my F250 EASILY tows it.
Ivylog
With a 6spd tranny and torque converter, higher gear ratios (3.73) are not that important any more. Way more truck that what you need for that light a load... go for it with a 3.31. Even if down the road you get something much bigger, and need more power... turn off the OD. As for getting started, that's what a torque converter does for you.
Upgraded with a 08 HR Navigator 45โ€™...
artguys
Join Ford Truck Enthusiasts...that forum is loaded with members that would be anxious to answer that question.
nremtp143
You won't know the difference! As stated above, hook up and enjoy. The only thing to be aware of is that your face may begin to hurt from all that smiling you will be doing!!!!
2016 Montana 3790RD, Legacy Edition, G614s, TST TPMS
2008 Thor Vortex 26FS
2013 F350 DRW 6.7L 4x4, Edge CTS, B&W Companion, Viair 10007 Air System, Firestone Air Bags
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
The_Mad_Norsky
You should be fine.
Hook up and enjoy that beast.
The Mad Norsky, Doll, Logan and Rocky
2014 Ram 3500 w/ Cummins/Aisin
2019 Northern Lite 10-2 EX CD LE Wet Bath
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
Turtle_n_Peeps
It will be fine. If you do the math Ford really only has one ratio anyway............or close enough.
The rule is, the more HP you have the less gear you need.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
