Oct-31-2013 11:01 AM
Oct-31-2013 07:20 PM
Oct-31-2013 05:23 PM
stap wrote:
I've read the few synthetic transmission fluid topics, but perhaps not being a "car girl" I don't see a reply that I can understand. What has been your experience with, or would it even be wise, to replace the transmission fluid in a front wheel drive tow vehicle (towing 4 wheels down) with synthetic fluid? My hope is to keep the fluid cooler while towing without adding a fluid pump.
Oct-31-2013 04:31 PM
Dr Quick wrote:
Are you talking about the "Towing Vehicle" or the "Towed Vehicle"? If it is the towing vehicle, yes synthetic would be better.
If you are talking about a vehicle that you are pulling,(towed) using synthetic will not keep from the need of a "pump" to circulate fluid. If vehicle manufacturer says that you can tow/pull all four down then, fluid type would not make any difference.
Oct-31-2013 03:17 PM
Oct-31-2013 01:17 PM
Oct-31-2013 12:27 PM
Oct-31-2013 12:07 PM
Oct-31-2013 12:05 PM
Oct-31-2013 11:05 AM
