Towing a vehicle on it's wheels
swimmer_spe
This may not be quite RV related, But I want to get a second vehicle and tow it behind my truck with all wheels on the pavement. The second vehicle might be a 4x4.
Is it as simple as putting it in neutral and tow it?
I want to control the towed vehicle's lights by my truck. Could I just hook up to the trailer wiring on both vehicles?
How do I avoid killing the towed vehicle's battery?
8 REPLIES 8
swimmer_spe
vic46 wrote:
:S
Old-Biscuit wrote:
swimmer_spe wrote:
I am looking at older Jeeps. It sounds like those can be.
I saw the link for each model year. I wish they had a simple drop down menu. It would be much quicker.
Yeah......it's a real pain now a days doing research
:S
It is easier than waaaaay back when, when all you had were cars that were only human powered!
I still think it could be made more user friendly
vic46
:S
:S
[COLOR=]Never argue with an idiot. You will be dragged down to their level and then beaten with experience.
Old-Biscuit
swimmer_spe
Ivylog
You will get better answers if you ask a MOD to move it to the "Dinghy Towing" section and yes it's RV related there. I learn the hard way that just because a 4X4 Pathfinder has N position in the transfer does not mean it can be towed 4 down. See "How I tow "below.
Upgraded with a 08 HR Navigator 45’...
bobndot
opnspaces
Navigator
Navigator
It kind of depends on the vehicle you are towing. the owners manual will tell you if you can tow it 4 wheels down or if you need a dolly or driveshaft disconnect.
Old-Biscuit
Not all vehicles can be tow 4 down....even 4X4
Before buying VERIFY it can be towed 4 down and what restrictions may be applicable (usually good info about towing is in the vehicles owners manual---available on-line so it is easy to check each particular vehicle you might have in mind)
Yes a trailer plug can be used....
Battery.....some times a fuse can be pulled
Again BEFORE buying VERIFY 4 down towing and investigate 'BRAKING'
