Aug-27-2015 06:38 PM
Aug-30-2015 01:36 PM
Meechy wrote:Wouldn't hurt to have them if you're so inclined. Just for comparison, on our '05 we do not have airbags and tow with more tongue weight than you'll be carrying, and do not have any noticeable sag. A lot depends on how well dialed-in your WD hitch is.
Also someone mentioned air bags for the rear? Any thoughts on this folks?
Thanks,
Aug-30-2015 08:42 AM
Aug-30-2015 08:41 AM
Aug-29-2015 06:42 AM
Tvov wrote:
I would think the tires on the camper will be fine... a 2015? Did you buy it new? Even if it is used with some miles on it, I can't imagine the tires will be in that bad condition. Obviously make sure you have a spare tire - AND the tools to change a tire on your camper - jack, lug wrench, etc that fit correctly. You'll be fine!
Aug-29-2015 06:03 AM
Aug-29-2015 05:55 AM
Aug-29-2015 05:47 AM
Aug-28-2015 09:20 PM
eluwak wrote:
The problem isn't cooling, it's radiator failures that cross contaminate the trans fluid with coolant and it destroys the trans pretty quickly. Nissan extended the warranty on the radiator, but if it destroyed the trans they were denying folks the trans repair. The best way to fix it is to bypass the radiator, install a gauge, and then see if you need an aux cooler.
It should do fine, but install some airbags in the rear to keep it off the ground. And like said, don't be afraid to tow in 3rd for extended periods of time. Ours had no problems holding 60 mph towing a TT too big for the truck.
Aug-28-2015 07:28 PM
kvangil wrote:
You DON'T need to add an aftermarket trans cooler. The stock cooler is plenty sufficient.
Aug-28-2015 05:23 PM
Aug-28-2015 05:16 PM
Aug-28-2015 04:12 PM
Aug-28-2015 09:01 AM
Aug-28-2015 08:20 AM
