Aug-19-2015 09:24 AM
Aug-20-2015 12:17 PM
Aug-20-2015 10:14 AM
lawrosa wrote:The OP can prove it if he would post o picture of the door jamb sticker. Salesmen and web sites are trying to sell stuff - not sure why you would not look at the info specific to your particular TV.cbshoestring wrote:lawrosa wrote:
That 1850 lbs payload is questionable to say the least...
I dont believe it..
Here we go with the 1500's being low payload, grocery getters. For the record...I believe 4 door trucks with 6' beds are grocery getters...or as my boy say "convertible SUV's".
Guess that 1668 sticker on my truck is really only 668#....must be a smudge in front of it.
2013 RAM 1500 contractor, Reg cab, 8' bed (4X2) 5.7 Hemi.
yeah I know....1668 is 182 light of 1850. Must have been that factory installed tow package that did me in.
gotta go now...wife wants milk and bread.
OK your 1668 may be right.. You know why?
Reg cap 2 wheel drive...
If it was a 4 door with options and 4x4 the payload stays similar less weight of 4x4, 2 more doors, and two more people in the back seats.. ( His kids)
Now tell me what the OP's payload is remaining? ( Note we dont know what he has yet) That 1800 just got reduced big time IMO...
500 for 4x4 stated in every manual I have read... so 1800 is now 1300. Two 100 lbs kids and gear now we down to 1000 say. Add the wife 100 ( If she is skinny and we down to 900.. And it can be a lot worse... Most never know...
So your 2x2 reg cab fitting 3 people is of course going to retain payload...
Its a no brainer if you know about trucks, payloads , and weights...
Id love to tow with a reg cab work truck 2 wheel drive any day... Thos trucks have the most capcity period...
My opinion of course... But true.. Hope someone can prove me wrong....:)
Aug-20-2015 08:57 AM
Aug-20-2015 07:49 AM
pb65stang wrote:
You're right about the 2015s having the increased payload potential. The interesting thing is that it's not translating to many of the higher end models. Many King Ranch's and Platinums are in that same 1400-1600 range, due to all the new heavy options. I specifically ordered mine without the heavy double moonroof so that I could save my payload.
Aug-20-2015 07:47 AM
Wishbone51 wrote:
Not apples to apples, but I have a Nissan Titan with a 7500lb limit, and a much lower payload than yours. I have a trailer with a 6500 dry weight. I have plenty of power to keep the speed limit, but the issue is transmission temp, and because of this, I am very slow (35mph) on hills and cruise on flat ground at 55mph. This combination is very stable, though, especially when I have some extra fresh water on board (tank is up front). Feels really good towing. Certainly not "white knuckle"
Aug-20-2015 07:44 AM
Aug-20-2015 06:51 AM
Slick87SS wrote:
Is the max tounge weight where the WDH would help? I will check the sticker on the door and post what the specific truck I am looking at says and post for you all. Should be able to later today
Aug-20-2015 06:27 AM
SilverEscape wrote:pb65stang wrote:
Just an FYI, I have a 2015 F150 SuperCrew 4x4 King Ranch pretty well loaded with options and my payload sticker says 1699. And that's with heavy stuff like power running boards, cameras, and 20" rims. So in a newer half ton, I could see 1800 depending on the options. I'm looking to tow about a 6,300 lb dry trailer with a 700 lb tongue weight and I have no reservations about it. Still leaves me 1000 lbs for people and gear.
The 2015's are aluminum bodied and gained several hundred pounds of payload per model though.
I've got a 2014 F150 SCrew 5.5' box, Platinum model with power running boards, AC seats, power mirrors, etc. and my payload is 1527. And I had to get the Max Tow option to get that. Standard Platinum models with the regular tow package had 1000-1100 pounds payload. The 2015's would up that a bunch.
For the OP, I'd check your yellow sticker on your door, the max tongue weight on your hitch receiver (for example, my max is 1150 tongue weight I believe for the receiver), and your rear gross axle weight rating. Those things will be your limiting factors.
For us, we have some room to play in our rear axle weight and payload with our trailer tongue weight of 771 and a trailer weight of about 5500. We need that extra play room for the kids to grow. So we couldn't comfortably tow a larger trailer without upgrading to a same series truck with less features or a larger series truck that wouldn't fit in our garage and I wouldn't be able to park. (although the 2015 F150s have my eye. We just didn't have the time to wait for them to arrive or the extra $$ to pay for one over the sale on our '14).
Aug-20-2015 04:39 AM
Aug-19-2015 11:01 PM
Aug-19-2015 07:33 PM
Aug-19-2015 06:50 PM
Aug-19-2015 06:37 PM
Aug-19-2015 06:33 PM
Aug-19-2015 05:43 PM
I'm not sure where you came up with this.
