Jun-26-2020 08:43 AM
Jul-09-2020 06:44 AM
dnezfrly wrote:
I have Gulfstream Vintage Cruiser 17rwd travel trailer which comes with mount for backup camera. But in my search to choose a camera, they all come with a mount so I am confused how to know what might fit in the mount already in place in the back of my travel trailer?
Jul-08-2020 07:58 PM
Jun-29-2020 07:41 AM
valhalla360 wrote:dnezfrly wrote:
yes, it is 20'. what do you mean watch out? fresh water tank is under the bed, which is at front of trailer. what i am reading is cargo weight should be forward, if at back will cause more sway.
Towing is best with high tongue weight. 10% is bare minimum. 12-15% is generally considered good. Even higher is better...this is why 5th wheels with 20-25% tow so well.
BUT!!!!!
Your Subaru likely has limited payload and tongue weight capacity. If you load up the front with gear and fill the water tank in the front...you could wind up overloading the rear axle of the tow car. That would negate any benefits of keeping the tongue weight percentage up as it can create other issues.
Jun-28-2020 10:49 AM
Jun-27-2020 08:15 AM
dnezfrly wrote:What I mean to watch out for is too much hitch weight. If you fill a front tank with 35 gallons of water, that's 290 lbs; half or maybe more than half of that weight will be on the hitch, depending on exact tank location in relation to the axles. That's how I bent a spring.rexlion wrote:
I can't see any reason why a sway bar would be bad. I think you have to keep in mind that rain (wet) will reduce the amount of friction supplied by the bar. And I hear that they have to be loosened before backing up sharply or the bar can get bent. Of course, the best protection against sway is to make sure you have at least 10% (but no more than 15% generally) of total trailer weight on the tongue; in your case you probably want 350 to 450 lbs actual hitch weight when loaded for camping. (If the fresh water tank is under the front bed, be careful! Water is 8.3 lbs/gallon.)
How long is the trailer? I'm guessing 20'?
Jun-27-2020 06:01 AM
Jun-26-2020 08:18 PM
Flute Man wrote:
If the trailer is loaded properly you should not need a sway bar.
If it was me I would try it first before I invested in a sway bar.
Jun-26-2020 08:15 PM
campigloo wrote:
I like sway bars. It’s true that if you’re loaded properly you shouldn’t need it. I’ve found they can be really nice in unexpected gusts of wind coming broad side.
Jun-26-2020 08:09 PM
Jun-26-2020 05:16 PM
Jun-26-2020 04:46 PM
Jun-26-2020 11:19 AM
Jun-26-2020 10:11 AM
