Trailer Brakes -- At What Size/Weight
Triton318
At about what size (length) and/or weight do travel trailers usually have brakes?
Thanks.
15 REPLIES 15
Triton318
Thanks for all the replies, and the link to the guide by states. Basically I was trying to figure out if I was going to need to get a brake controller for my truck when I buy my travel trailer. And the answer is "yes." Thanks!
bmj11
I think peoples are not reading the guide for all states and provinces I have given.
http://drivinglaws.aaa.com/laws/trailer-brakes/
CavemanCharlie
I had a 1969 TT with one axel and it did not have brakes. In MN any trailer over 3000 pounds must have brakes.
mileshuff
My first popup weighed 1000lbs loaded and did not have brakes. My 2nd popup weighted 2000lbs and came with brakes. I wouldn't want to go any higher without.
The relation between trailer weight and braking ability of tow vehicle will affect decision. If you have a semi rig you may not care if your 3,000lb trailer didn't have brakes. Semi probably wouldn't know the difference.
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
westend
Those Kentucky trailer requirements may be true but everyone should check with their State Police to see what is exactly the law. Like in Kentucky, it may apply to you but not if you are a Farmer. Look in the FAQ section, 3000 lbs and above requires brakes and also emergency break away.
'03 F-250 4x4 CC
gunner65
Kentucky
Kentucky law does not specifically require brakes on any passenger car trailers, regardless of weight. However, vehicles singular or in combination must be able to stop within distance specified by statute.
Nvr2loud
downtheroad wrote:
mich800 wrote:
Nvr2loud wrote:
downtheroad wrote:
Travel trailers are required to have a, "brake away," system...to stop it if it comes un-connected from the tow vehicle while underway.
To have this system, the trailer needs brakes and a battery to operate these brakes.
Not true everywhere.
I will need to check again but it was if it was required to have brakes then the emergency brake was also required. I know for a fact that most open two place trailers have no brakes.
Where is it not "true?"
....and we were talking about travel trailers not, "open two place trailers."
In Ontario it is not required to have brake-away brakes.
I have 4 trailers now all purchased in Ontario and legally licensed for the road. Two are travel trailers, neither has brake-away brakes. One of my other trailers is an enclosed 6 x 12 utility trailer, with brakes, without battery and brake-away. My fourth trailer is simply a boat trailer.
downtheroad
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
mich800
bmj11
You have most of the law for an RV for USA and Canada here
If you click on the subject on the blue column on the right side, you have a lot more
Nvr2loud
APT
Any double axle trailer RV will have brakes on both axles. Most single axles do too which GVWR around 3500 pounds. Popups are where you need to ask if certain models have trailer brakes.
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
beemerphile1
I've never seen a TT without brakes. Some smaller trailers don't have them, check the laws in your state. If I recall correctly the maximum in any state is 3,000#. Many states require brakes at a lesser weight.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
downtheroad
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
