โAug-28-2014 03:31 AM
โAug-29-2014 01:33 PM
โAug-29-2014 01:03 PM
proxim2020 wrote:buzzard616 wrote:
Slight twist to the topic but I'm curious about 'ramping' one wheel to raise the other off the ground.
Doesn't that result in the ramped wheel/tire/hub supporting almost twice the design load?
Stu
Wouldn't the load be split between the remaining 3 units?
โAug-29-2014 10:35 AM
โAug-29-2014 06:21 AM
Stu
โAug-29-2014 03:25 AM
Stu
โAug-28-2014 06:14 PM
โAug-28-2014 04:21 PM
โAug-28-2014 09:10 AM
โAug-28-2014 06:26 AM
The axle tube is very thin-walled and if you lift under the tube, you are likely to bend the axle. Don't do it.
โAug-28-2014 06:09 AM
โAug-28-2014 05:42 AM
PackerBacker wrote:pasusan wrote:
It depends on what type of axles and frame your trailer has. Best bet is to check in your owner's manual.
I agree. I know on mine I lift with my floor jack and a block of wood under the U bolts.
โAug-28-2014 05:21 AM
โAug-28-2014 04:04 AM
โAug-28-2014 03:59 AM
