Trailer Off Tires for Winter Storage???
Rbertalotto
I'm a bit new to TT. This is my first winter storage of one. Had Truck Campers until this year.
Do you TT owners put blocks under the spring perches to take the weight off the tires during winter storage?
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
25 REPLIES 25
JIMNLIN
...and why is this necessary?
I'm open minded and just trying to learn...
Per Carlisle;
โ€“ Keep trailer tires in a cool dry place and out of direct sunlight
during storage.
โ€“ Use tire covers to protect tires from the harsh effects of direct
sunlight, moisture and temperature extremes.
โ€“ During extended storage, use a thin piece of wood or other surface
barrier under tires to extend tire life. For seasonal or extreme long
term storage, elevate the trailer on blocks to take the weight off the
tires. Reduce the air pressure and cover the tires to protect them
from direct sunlight.
Per Maxxis;
Tire Storage
Maxxis recommends storing tires indoors in a clean, cool and dry area away from UV rays or ozone gases (eg. generators). Tires should be stacked flat and reduced to 15 psi if mounted on wheels during storage.
If tires must be stored outdoors, Maxxis recommends raising tires off the storage surface to avoid excessive contact with the elements. If possible, wrap the tires in an opaque polyethylene cover to minimize the effects of ozone and oxygen.
If a trailer is being stored without removing the tires, place blocks under the trailer to remove all weight from the tires. Avoid moving the trailer during extreme cold weather.
Always adjust inflation pressure before putting tires back into service
Per Goodyear;
Storing your vehicle properly helps protect your tires.
โ€ข Keep your vehicle in a cool, dry storage area out of direct sunlight and UV rays.
โ€ข Unload your vehicle so that minimum weight is on the tires.
โ€ข Inflate your tires to recommended operation pressure plus 25%, but donโ€™t exceed the rim
manufacturerโ€™s inflation capacity.
โ€ข Thoroughly clean your tires with soap and water before storing them to remove any oils that may have
accumulated from the road.
โ€ข Move your vehicle at least every three months to help prevent cracking and flat-spotting,
but avoid moving it during extremely cold weather.
โ€ข Place your vehicle on blocks to remove the weight from the tires. If the vehicle canโ€™t be put on blocks,
make sure the storage surface is firm, clean, well-drained and reasonably level.
Now if anyone need to know why the tire makers recommend all this ...give them a 1-800.
My RV sits on 2" x 8" x 48" long on limestone crusher run in a trailer shed out of the sun. I keep LT tires on my trailers at max pressures 24/7. I change them out at 7-8 years and 50k-55k miles as their getting close to the wear bars.
IMO the best idea is keep them dry and out of the sun when sitting for several months.
downtheroad
3oaks wrote:
downtheroad wrote:
I need help with this...why are you jacking, raising and blocking your trailer?
Because some owners prefer to take the static load off the suspension and tires while their trailers are in storage for several months.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
3oaks
downtheroad
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Jack_Diane_Free
I usually pump up the tires 5-8 lbs over normal to reduce flat spots. Do not know if it has made any difference but I still do it.
Lynnmor
When I had a smaller trailer and no indoor storage, I did take some weight off the tires. I lowered the front a few inches and then built up blocks to the frame just behind the wheels. Then I raised the tongue to level. Now I could deploy the stabilizer jacks without worry of a tire going down and over loading the frame at one corner. It is all pretty simple and benefits the tires. With eleven points of ground contact, the trailer is more stable if it is exposed to high winds. It is worth doing and it only takes a few minutes once you have the blocking.
downtheroad
Don't make this more complicated than it is.
Keep it simple and easy and you will find yourself camping a lot more.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Campfire_Time
Most don't. I don't. And you have to be careful. If you have Dexter torsion axles you can't jack them up or put blocks under the axle itself otherwise you'll damage it.
Many years ago I used to see people put 'em on blocks. The thinking was that it somehow protected the tires. It didn't make any difference.
I park on a gravel pad and have 2" boards under the tires so it doesn't sink in the spring when the ground is wet.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
Campfire_Time
I park on a gravel pad and have 2 in boards under the tires so it doesn't sink in the spring when the ground is wet.
Chuck D.
ChooChooMan74
X2.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
donn0128
No! Park it, winterize, plug in close it up.
