โAug-15-2020 03:35 AM
โAug-18-2020 02:25 PM
โAug-18-2020 01:27 PM
โAug-18-2020 12:50 PM
โAug-18-2020 10:16 AM
jotityra wrote:
I'm sure the tires are of the P metric variety. the truck is a lease vehicle so changing the truck tires will probably not happen.
โAug-18-2020 09:21 AM
โAug-18-2020 08:27 AM
โAug-17-2020 05:17 PM
aftermath wrote:
joytitra, just read through your thread again. I still say you need new trailer tires but another good point was raised. What truck tire do you have? I purchased a new tundra in 2008 and pulled my hybrid with it. When I got my Airstream I had to reset the hitch and it looked good. I had many miles towing with it until one day I felt a tiny bit of sway coming down a slight hill. I had some kind of P rated tire and read that weak sidewalls will create sway. I was due for new tires and moved up to LT tires and it made a lot of difference. So, trailer AND truck tires might be issue.
โAug-17-2020 05:15 PM
aftermath wrote:
At five years out your original tires need to be replaced anyway. I had a Starcraft hybrid that wasn't nearly as heavy as your trailer. It came with C rated tires and I had a blowout soon after getting it. It met load ratings, but just barely. You need tires that will cover your trailer load and then some. I now have LRE tires (on a different trailer, 6500 lbs going down the road) and am very happy with them. They will carry up to 80PSI and have a speed rating of 75 or 80 MPH I believe. I run 70PSI and keep my speed as close to 65 as I can. Your plan to look at the new Goodyear is a good one. How much does your trailer weigh? Don't be afraid to move up to a LRE. You won't be putting "rocks" under your trailer.
Get the new tires, tweak your hitch some more and you will be good to go.
โAug-17-2020 05:09 PM
wclement1248 wrote:
I had sway problems with my F250/TT with sway bars. i tried turning off the sway control function in the truck. apparently sway bars and sway control work against each other. Might work for you
โAug-17-2020 09:59 AM
MarkTwain wrote:
I would start with switching to a 16" rim if it will fit and "G" rated tires.
โAug-17-2020 09:50 AM
โAug-17-2020 09:35 AM
โAug-17-2020 09:25 AM
โAug-17-2020 08:54 AM
