Tranny fluid change
azdryheat
Got 70,000 miles on the current ATF oil, so today it and the spin-on filter got changed. I also dropped the pan to see if there was any sludge and it was clean. Love this Duramax/Allison combo.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
60 REPLIES 60
Grit_dog
Navigator
Navigator
4x4ord wrote:
^^^^Trucks donโ€™t need maintenance. It costs virtually nothing to replace a truck. Women on the other hand, they need maintenance.
Apparently you have magic trucks and the wrong women...
4x4ord
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
Grit_dog
Navigator
Navigator
Cummins12V98 wrote:
4x4ord wrote:
Cummins12V98 wrote:
If anyone has figured out how to do a fluid exchange on an AISIN please post method. IMHO it's stupid to not remove all the fluid.
Doesn't Ram include fresh clean fluid when you order a new 2022. Just think it would come with fresh engine oil, tranny oil, new brakes, tires and antifreeze. New paint and chrome, new seats, updated nav system, 425 HP and 1075 lbft of torque plus bumper to bumper warranty and all for just three easy payments of $9,000 plus a 1/2 worn out, tired old sheep that is ready to be turned out to pasture. What are you waiting for ... or if you really want to have something to get cranked up about you could turn off one block sooner.
I have always liked how you can rationalize buying a new truck when the mood hits. :B
Yeah, I feel sorry for the poor sobโ€™s that get 4xโ€™s used trucks. Iโ€™ve never been able
to subscribe to the run until you trade it in, maintenance be dammned, approach.
Grit_dog
Navigator
Navigator
^Interesting.
I havenโ€™t done it yet, but on the 68rfe I recall reading about disconnecting back by the trans to do a fluid replacement. Maybe to bypass a thermostat that recycles fluid until hot, like you experienced.
Cummins12V98
Grit dog wrote:
Man, some of you guys are just incessant!
That said, 12V, why couldnโ€™t you do a trans fluid replacement like any other trans via the cooler line?
When it was time for my Son's 15 to be serviced we poped the line by the radiator all we got out was a dribble. My 11 68rfe worked like a dream.
Sounds like there is some type of solenoid on the side of the trans. Wish I knew where to safely tap the converter.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
4x4ord
^^^ Some transmissions have a bypass valve that allows fluid to bypass the cooler unless it is hot.
B&W Companion
Grit_dog
Navigator
Navigator
4x4ord
B&W Companion
Cummins12V98
Old Mechanics tale.
FishOnOne
Huntindog wrote:
rhagfo wrote:
Cummins12V98 wrote:
"I also use used oil in the gasket, can always remove by hand and not a leak yet."
The "YET" part is what scares me. If the filter says tighten a certain amount after contact I do so. Honestly if a filter can be removed by hand after 5-15,000 miles that is loose IMHO.
Ron, tighten by hand the 3/4 turn past gasket contact, it is tight. I didnโ€™t say it spun off easily at change. I wear a playtex rubber kitchen glove for heat resistance and better grip. I have been doing this way since an oil and filter change on Dadโ€™s 59 Ford 352. Destroyed the spin on filter getting it off had gone on with clean oil on the gasket, and likely a full turn after gasket contact, that was about 1967,!
The 2001 ran 10k between changes.
Mechanics trick: use old oil on the gasket. Then it will always release for the next change out.... Do not worry about a couple of drops of old oil on the gasket.
Why old oil vs new oil?
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Huntindog
Huntindog
100% boondocking
2 bathrooms, no waiting
17.5LRH commercial tires
FishOnOne
Cummins12V98 wrote:
FishOnOne wrote:
Cummins12V98 wrote:
Hey "FISH" You have not answered my question!!!
I did... By having to change out the transmission fluid every 30k miles you don't have to worry about flushing the transmission.
I don't "FLUSH" my transmissions.
Don't think you answered my question. Did you change "ALL" your trans fluid when it was serviced?????
No... Simply drained the oil pan at 100k miles. At 180k miles I removed the oil pan replaced the filter, cleaned the particles on the large magnet and refilled. Currently at 214k miles and transmission shifts and performs excellent.
Keep in mind Ford recommends a 150k mile service so I did perform the first service early.
Cummins12V98
FishOnOne
