Trans temperature gauge
poncho62
OK, heres the deal...I installed an Autometer tranny temp gauge in my truck this morning...4L60 trans....Its about 35-40 degrees around here, winters coming...Went into town to run a few errands. Temp on gauge went to about 125F, that was about it. Ran a total of about 10 miles. Is this normal for this time of year?..How long should it take to get up to operating temp this time of year, or is this the normal temp for this time of year?
Just trying to get a baseline here, as I have never monitored trans temp before.
24 REPLIES 24
CKNSLS
Mark Kovalsky wrote:
That chart isn't 20 years old. It's more like 50 years old. It is useless for the modern world.
I've run modern ATF as high as 320ยฐF in testing. The seals didn't harden, the clutches didn't burn, varnish didn't form, etc. This chart is plain wrong for a modern transmission.
+1 ๐Ÿ™‚
Mark_Kovalsky
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
CKNSLS
partsman01 wrote:
Here is one chart I have.
Everybody - here is one of those twenty year old charts mentioned earlier. It has nothing to do in today's reality. Gm says Dexron 6 to 275 degrees-and they have even had the fluid up to 285 degrees.
partsman01
DougE
Mark, I yield to your expertise with no issue. I agree that the trans fluid will be the coolest if it goes through the vehicle radiator first and then through the trans cooler. This is great to control the upper temperature in hot weather. Apparently this is not the best overall solution in cold weather or modern transmissions would not come with bypass circuits to maintain a minimum trans fluid temperature. However, on older non-bypass transmission fluid circuits I would have to conclude that the maximum trans fluid temperatures were more of a concern to the manufacturers than minimum trans fluid temperatures.
Currently Between RVs
Mark_Kovalsky
DougE wrote:
If you search some you will find most sources state that the design operating temperature of automatic transmissions is 175*. You will also find that most life vs. temperature charts for auto transmissions do not go below 175*. This is the reason behind installing an auxiliary cooler prior to the radiator cooler. This allows cool trans fluid to be warmed up to the correct temp as the outlet of the engine radiator is ~175*.
The engine radiator is NOT ~175ยฐF. It usually is MUCH colder than that. Have you ever measured the temperature in the cold side of the radiator? I have, in ambient temperatures from -40ยฐF to +115ยฐF. When towing heavy in high ambients the temperature drop across the radiator can be as small as 15ยฐF. But in cold weather, running lightly loaded the cold side of the radiator is within a few degrees of the ambient temperature. If it's 0ยฐF outside you can expect the cold side of the radiator to be around 5-10ยฐF. How well is THAT going to warm your ATF?
The correct routing for the ATF flow is from the trans to the radiator cooler, then to the aux cooler, then back to the trans. This is the way all of the auto companies route it because they understand how the system works.
But you are right, the designed operating temperature of the trans used to be about 175ยฐF. It has moved higher in recent years to improve efficiency. Newer fluids and materials in the trans are designed to live at those temperatures.
Those charts that are floating around the internet that talk about trans death in feet instead of miles if the trans ever gets above 200ยฐF are based on 1960's technology, or just flat out lies.
Mark
Norskeman
Today - max temp of 30 degrees. Tranny temp on the way home was only 100 deg F. Just not enough load on the tranny to heat it up. I have a diesel and an Allison so it may not be a good comparison.
2017 Keystone Avalanche 320RS
TV - 2011 Chevy Silverado 3500HD LTZ CCLB Duramax SRW 4X4
deadeye1
I have a F150 (7700 series) with 4R100. Extra oil oiler and temperature gauge in the oil line going into the rad. Oil temperature in winter never goes about 100ยฐ unless I'm in town. In the summer it runns about 140-150ยฐF pulling our 24 ft 5th wheel. Only time I have seen it go 170 or higher was stop and go traffic or parking or going up a couple of grade in the White Mountains in July. The temperature will go back down the minute the torque locks up. Their is a temperature bypass in the $R60 and 100 that will not allow it into OD unless the tranny is at operating temperature.
OH48Lt
Don't many transmissions have a thermostat that bypasses the cooler until the fluid comes up to a certain temp? Don't know about the 4L60, but the 6-speed in the F150 in sig below must have one. It'll warm up to 195 and stay there despite the outside temp. The only time I saw it get higher was while towing the TT up Wolf Creek Pass in Colorado (10,700 feet). It went up to 204 then, and went back to 195 quickly on the way back down.
2017 Ford F-150 Crew Cab 4x4 3.5 EcoBoost
2014 Cruiser RV Fun Finder 215WKS
2015 Harley Road Glide Special in Amber Whiskey
2019 Mustang Bullitt
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
DougE
bmanning - I'm not disagreeing with you. My primary point was to recommend against trying to run trans fluid at too low of a temperature as it is not necessary. If you run too cool you never boil off any condensation that has collected inside the trans. Most, if not all, trans cooler sellers want you to mount their cooler after the vehicle radiator. Looking, I suppose, to get the most cooling of the fluid and thus make their cooler look the most effective or to mitigate other cooling system problems that should have been addressed first. I agree with you that modern fluids can operate successfully at higher temperatures than in the past. The '91 Class A I had previously would easily generate temps above 250* on long uphill runs and benefitted greatly from a quality plate trans cooler.
Charlie_D_
My 2013 D/A has Dexron VI. Good stuff but it is not synthetic.
Go to the Class A forum and search "Let Me Know if You Have Allison Transmission Fluid Questions" It was started by the former Transmission Fluids Engineer at Allison Transmission. Excellent reading.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
CKNSLS
bmanning wrote:
CKNSLS wrote:
Yea, there is a trans temperarture chart floating around the internet that's been wrong for ten years. There is no "normal" as long as it stays within the temoerature range where the fluid is designed to work. See my post above.
x2
Those charts can be extremely misleading, as they're based off of obsolete trans fluid technology. Much wiser in 2013 to go by either a) the truck manufacturer or b) the maker of the fluid itself.
Would take some getting used to, but I'm thinking a modern trans with today's synthetic fluid could run 240-250F for hours on end with no consequences.
You are correct sir. The Dexron 6 (and other competitive fluids) can take temperatures that were unheard of years ago.
bmanning
x2
BManning
baking in Phoenix :C
-2007 Volvo XC90 AWD V8
4.4L 311/325 V8 6sp Aisin loaded
6100lb GVW 5000lb tow
-1999 Land Cruiser
4.7L 230/320 V8 4sp A343 loaded
6860 GVW 6500lb tow
RV'less at the moment
DougE
I wouldn't base off 1 chart. There are many. Could be they are all copying one original but since some baseline at 185* I tend to doubt it. I've also checked some of the "white papers". Although they have to be designed for a wide range of temperatures and fluid characteristics there is a "design point" in there where all conditions are optimal. My SWAG is 175*. Your SWAG can certainly vary.
