โNov-05-2013 07:27 AM
โNov-13-2013 05:25 PM
โNov-11-2013 06:15 AM
goducks10 wrote:Rthomas61 wrote:
I'd be interested to see what people think of the ecoboost f150's. Looking at them vs. the Chevy 1500 V8's. Ecoboost V6 ford F150 with 3.55 rear end is indeed 9600 lbs. saw that the other day. Kind of has me intrigued but I've always been a Chevy guy.
I would never tow with a 6cyl.
โNov-11-2013 02:22 AM
โNov-10-2013 07:29 PM
'15 Chevy Silverado 2500 HD
'18 Forest River Avenger :C "Dolci"
Kipor KGE3500Ti
CHECK OUT THE RV.NET BLOGS!!
โNov-10-2013 05:58 PM
โNov-08-2013 06:06 PM
โNov-08-2013 02:12 AM
โNov-06-2013 07:26 AM
goducks10 wrote:brulaz wrote:
yep, it's all about low-end torque when towing, and that's where the diesels and Ecoboost shine. As do the big V-8 and V-10's, but they consume a lot more fuel when not working.
But lots of low-end torque and tow capacity doesn't help when the available truck payload is too low for the trailer's tongue/pin weight. Ford's F150 trucks can have some impressive payload numbers if you get the right options. The Max Tow option helps add 400-500# to GVWR and payload.
But even better is the HD Payload option which can add as much as 1000#, with the improved suspension, rear axle and wheels effectively creating a hybrid truck somewhere between an F150 and F250. Unfortunately it usually has to be special ordered and is not available in all models/configurations.
Dodge RAM is introducing a V6 diesel with even more low end torque than the Ecoboost in their 1500, "half-ton" line this fall. But if they don't improve the payload of their light trucks it may be wasted.
Why would the diesel be wasted in the 1500 Ram. It's not a power house diesel it's more of an alternative motor for better mpg's. People by Ram 1500's to tow with so assuming the same tow ratings the diesel owner will get better unloaded mpg's and equal towing capability. Rams not putting that diesel motor in the 1500 to make it a tow monster. You could say the same thing about the Eco in Ford trucks with 1200lb payload ratings. I think people get fixated on thinking that since a truck has a diesel motor that it's supposed to be some power house towing machine.
โNov-06-2013 06:02 AM
โNov-06-2013 04:28 AM
โNov-06-2013 04:23 AM
โNov-06-2013 02:34 AM
โNov-05-2013 09:08 PM
โNov-05-2013 08:50 PM
I would and when I poped the hood it would say CUMMINGS inside
