Jun-10-2017 08:19 PM
Jun-13-2017 05:32 AM
lawrosa wrote:falconbrother wrote:
I would just do a drain and fill to be safe. I do drain and fills a lot. Takes five minutes and 3.5 quarts of Dex6. If you have to pull the pan it takes considerably longer but, still not a hard job, just messy. If you have to pull the pan put out some cardboard to catch the mess.
On my 4L60e I ground the head of the drain plug off and welded an 11/16 nut in it's place. Plug comes right out. Literally takes five minutes to do the job.
Is that what yours takes? My manual states 5 quarts. But thats with filter changes. I have the 4l60e.
So if I just pull the plug and drain im looking at 3.5 qt?
Jun-13-2017 04:05 AM
Jun-12-2017 08:49 PM
Frankly wrote:The gauge does move. You were still mostly in the normal zone so it does not move much if at all.
The temperatures were measured off the OBD2 with a scan gauge. Not sure how accurate these OEM sensors are, but it sure beats looking at the idiot gauges, which show very little if any change.
Jun-12-2017 08:40 PM
Jun-12-2017 06:04 PM
Jun-12-2017 05:46 PM
Jun-12-2017 11:12 AM
Rangerman40 wrote:
I just pulled from Ohio through the Rockies and all over Utah in 100 degree temps and my Aisin never saw above 170..... pulling a 15k lb fifth wheel.
Jun-12-2017 10:57 AM
Jun-12-2017 10:54 AM
Jun-12-2017 10:38 AM
Jun-12-2017 10:31 AM
Jun-12-2017 09:45 AM
Jun-12-2017 09:02 AM
Jun-12-2017 08:10 AM
