Apr-27-2017 04:52 AM
May-05-2017 05:52 AM
RAMwoodworks wrote:
Tire thread. Great, I have a tire question.
Should I get my tires balanced? They are new and only have the mileage from delivery and the 122 miles I put on them bringing my trailer home.
I only found one article online and the author said trailer tires don't need to be balanced because there is no lateral load on them at speed. Doesn't make sense to me.
If I do pull them off to get balanced where do I put the jackstands on my dual axle travel trailer?
May-05-2017 05:42 AM
May-05-2017 05:39 AM
JIMNLIN wrote:I don't think you're "de-rating" your tires by running less pressure than the maximum. There's load charts available at the tire manufacturer's website most times that tells you what pressure to run depending on the weight each tire will carry.
This isn't the best idea for tires used in a trailer position as Roger Marble in rvtiresafety.com explains and other industry experts tell us.
Then along with ply shear and tread separations caused by derating the tire pressure to a minimum is the OP went with the Carlisle ST tires which require using max sidewaLL pressures to satisfy Carlisle tire warranty.
Carlisle says;
-Maintain air pressure at the maximum PSI recommended on the tire sidewall.
**The Warranty is void if the tire or wheel fails due to damage from improper inflation pressures, exceeding the maximum speed limit, or overloading the tire beyond the maximum load capacity stated on the sidewall**
May-05-2017 05:14 AM
May-04-2017 05:47 PM
May-04-2017 05:19 PM
May-03-2017 10:43 AM
Apr-28-2017 08:41 AM
Apr-28-2017 08:24 AM
katoom400 wrote:
AT 7500lbs GVWR, my trailer should be more than fine with D Range tires @65PSI
My question is: Since it is only $6 more per tire, is there any drawback to going with E (10 ply) tires? Overkill? maybe! but for the price of a 12 pack of decent beer why not?
Apr-28-2017 06:27 AM
Apr-28-2017 06:02 AM
JIMNLIN wrote:
Just a comment here but at some point more tire on a trailer isn't the best idea.
If you think a load E tire at 2830 lb capacity is a good idea then another upgrade to a 16" load G tire at 4440 lb capacity would be better ? Not trying to be a wize azz but justy making a point.
Apr-28-2017 05:40 AM
Apr-28-2017 05:33 AM
Apr-28-2017 04:40 AM
