To the OP
To your question, I had a 2009 Toyota Tacoma which was rated for a 6500 # trailer, had 236 horsepower, and 266 lbs-ft of torque. Can't remember the payload number, but I believe it was something just under 1500#. I towed a Springdale 202 which scaled at about 5300 pounds loaded. Tongue weight was close to 600 pounds. I had an 800 pound Husky spring bar hitch with one friction bar for sway control. I used a Tekonsha P3 for brake control which I still have in my current setup. Braking was never an issue even in the mountains.
I would say that the truck itself was adequate for the pull under most conditions. When it became stormy with cross winds, or a semi passed from the rear, the setup deficiencies became obvious. The wind in either case would move the combination around a bit. Sway was not a problem at all, but I became aware of the weight behind me for sure. Never dangerous, but the comfort level while driving definitely decreased. Not a relaxing drive for sure. Having said that, the motor was great on the flatter ground, but when we were in the mountains or driving into a head wind, I was definitely wishing for more power.
I ended up trading the Tacoma for a 2013 Tundra which was like night to day in terms of ability to tow, and comfort while doing so. I should say that I have towed a variety of trailers for 20,000 miles or so, so experience is not an issue. At least some would say!
๐In my opinion, the proper setup for a trailer of that weight would include at least a half ton truck and another 100 horsepower. The added weight of the truck is a bonus, and more power is always great but with the poorer gas mileage as a down side.
I would suggest going to a dealer that would allow you to take the trailer that you are interested in for a test spin and go to a truck scale while you have it to get the real weights that you need to make a determination on whether or not you are within specs of your Jeep, and more importantly to get a sense of your comfort level while on the road.
http://auto.howstuffworks.com/auto-parts/towing/equipment/hitches/towing-weight-distribution-systems.htm
Hope this helps.
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
