Truck camper help!
Rychess
Hey there, New to this site and also truck campers and was just looking to get a littlehelp here. I was just given a 9 and 1/2 foot truck camper, though he does not know how much it weighs. I assume its from the mid eighties as well. The only question I had was, would I have any trouble hauling this in a half ton truck? Any info would be appreciated. Thanks.
Also, the truck is a 1991 Chev Silverado 1500, if that is relevant.
10 REPLIES 10
tonymull
Redsky wrote:
tonymull wrote:
For that truck you will have to look at popups most likely.
Not true. I have had hard side campers on both 1/2 ton and mini trucks. You may not get a separate bathroom or forced air heating or a large fridge but they are do the job very well for those who can "rough it".
I have a hard side now, a light one but I'm well over. I'll be upgrading my truck this winter. But with 1/2 ton pickups having 1500 lb payloads or less, what models are you talking about...the camper would have to have a dry weight under 1000 lbs to even have a shot.
Bigimac
12-mths, 19-trips in my TC, & lots of $$$'s ago, I was exactly where you're at .... clicky
2013 Capri Sportsman Grande
2015 Chevy Crew cab 3500HD SWD gasser
Toyo Open Ctry ATII 275 70R/18
10150# loaded; 10.5 mpg @ 70mph
Redsky
Peg_Leg
Buy a utility trailer for it.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
Desertboy
Or you can get you a cheap trailer and mount it on that if the Camper is worth saving.
1969 AVION
3/4 12 VALVE
Freightliner/24' Flatbed 50,000 miles/ Titan 4000 receiver Hitch, no Mods needed.
tonymull
Rychess
Thanks for the help guys, appreciate it! Saved me a truck, ha! I'm sure I will be able to find something smaller.
Super_Dave
That "free" camper is going to cost you a brand new truck. LOL!
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
mkirsch
Nomad II
Nomad II
Even not knowing the weight of the camper, you can make an educated guess as to the weight based on campers of the same era and even more modern campers of similar size.
I agree with Tony's assessment that the camper weighs around 2500lbs. Even at 2000lbs, you're starting where most 1/2 ton camper operators end up. Like Tony said, you haven't even packed for the trip yet.
I'm sure you could load it for a one-time move, but as far as regular camping, no.
Beware though that if the camper is older than 1987 or so, it probably won't even fit in the truck! Around 1987 all the truck manufacturers started changing the sizes of their boxes, making them smaller and narrower.
tonymull
Yeah the truck will be very overloaded. Dry camper probably comes in at 2500+ and the payload for your truck is about 1500. Load up the camper with supplies and add some people and you are like double your capacity....
