Truck camper
karl1948
I hooked up to 30 amp shore power, all the lights in the camper went dim and then dimmer. Also the heater would not heat, everything else, plugs and heater/ ac worked fine. Not sure what the problem is.
6 REPLIES 6
tattoobob
There should be 1 or 2 30 AMP auto fuses in the 12 volt fuse panel I would check those first, and when mine were bad they tested okay but for some reason didn't work right when there was a 12 volt load on them after I replaced them everything was fine
2005 Ford F350 SRW 4x4
2000 Lance 1010
wvabeer
Check the fuses to and from the 12v converter/power supply
1999 Dutch Star DP3884
2015 Camplite 6.8C
2012 Cherokee 39L destination
2022 F350 XL 4x4
07 FLHRS
Farmboy666
Did the lights go completely out? You said heater would not heat but then said heater/ac worked fine?
GordonThree
Fuse or breaker connecting your 12v converter either to the batteries, or to the 120 volt supply.
jimh406
All of these things you mention are 12v powered. Look into you power convertor, battery switch and batteries.
If you have an inverter, turn it off.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
Lwiddis
Did you check the park 30 amp power supply? Polarity? Voltage? Prior to plugging in?
Is this a new TC? Has all this stuff worked somewhere else? In your driveway? Other parks?
